35 Summilux Pre Asph Hood - Redux
michaelwj
4:07 PM
Brisbane AUS
So I recently got a 35 summilux pre ash, complete with the original 12504 Leica hood. While the original hood is okay, the tabs really get in the way of the aperture and my copy is bit loose. On top of all this, it's a pain changing filters and it's expensive - so having two (one with a UV and one with a yellow for instance) so I don't have to mess around unscrewing the hood over and over would be out of the question.
A very quick search revealed that I'm not the only one who has sought an alternative solution. In particular, this thread had a wealth of information: http://www.rangefinderforum.com/forums/showthread.php?t=80916 and I found RichC's idea very neat: http://www.rangefinderforum.com/forums/showpost.php?p=1164783&postcount=20
Now, there is talk about the (37mm or 39mm) filter mounted in the front of this hood causing vignetting which is understandable as it is smaller than the front of the lens. I don't believe the hood by itself would cause vignetting int he corners - it's a rectangle so the corners are actually well out of the way. I also (non-scientifically) tested the naked hood on the lens and found none.
So what I was after was a clamp mounted to a Leica 12524(6) hood to stop it rotating, with the largest possible filter mounted as close to the front element as possible. No gluing so I can swap parts out if the filter gets scratched, but not necessarily "hot-swappable".
Here is my solution:
j4yy_4fXZwe1jlN-8A8kSbXscjcBj9gEQX5JxCNvhXmaU46zxSOPe7isLSNLUvN_t9OWB7FkyAHJjjCdi5uacGfrLZZG2iomwmsWBuT6HDAeeLZg6PFTbSY80Q_tKYHBkVj8STtJRHm9YFlmeLpqyJhcEb5FYa7DOOZrhKkQN6dRzxDzq3fMsUuq8uhp_IDO3Jqo9iaefAa0KRcjyvLXKSnyYLBz2nXYLyfJV2mSk2edne_FkByZlf78Yd6PEJGN6_Xz8GgLr5OcdAqvVlH3K5LWr8OXkb-pwChKZsd6x2WJJyAgTYoZC-kLpR6m_Y87HI2Ieix8iJ3Ikp6BRUhd_A6y42GhkIAyyFfLkLxQbqAkmisiCnpvPlGbVLJK_jQlfo4Murw_Ca31imZQpk8sxuc89zuNsQwIx-EOlYqPTmGSijXbH7pHV9HVIMXdnagZJXslC_Gn_DC1pRnrcSAf2ke35V_i9QR6OopcQb1kWtjUwDxB83okYztMq4l6ouf6ogIGmKqRoeaDOk5EofM1sIUpnxwWCMCughX74yFtqxxKM1u5xoHDdRb-9VXoRDTSealsO0YK8k9Apln72F2SNTHrwKj6V7Y=w1116-h837-no
And here is how I made it:
The parts you'll need:
1 x Leica 12524 hood (the spring clamp is removed, so if that bit's broken all good)
1 X 42mm clamp on hood - I used a Minolta D42KA cause it was cheap
1 X filter glass - The glass (no mount) needs to be between 43.7 and 46.6mm - I used a Pentax 49mm filter which fits perfectly.
First, remove the clamp(s) from their respective hoods and the glass from the filter. Remember that you need the clamp from the clamp on hood and the hood from the Leica hood! You can see on the Minolta clamp the lip that held the hood in place - this gets removed later.
2fwaAUMGyeVuZE0VsV39YeXljo_QJzVON0vWw1SWomr4Jjx26nE1Bd4PW-OMEzHIB_xdwNRjQ8VXUhtvGobfbfIHZRX_o5Gx3Yrz5efq1TOJNO-r4l2sIlVjME3E05Cn3PY7QvP4_0t32X_u1cnHfnp0DTel2J9eREYaDaVntwxEIjYQ0Ry9BG984sULNWfSkvs5mNwQAUK2wLTnB6cJciW080NgywW4bdzDN5lHN6aLeO7gWps_5LWmchDHeycVWqTiZ5rka1NtsZ7VGcQhBgnfvEMFhG_wwFphNz4bDpsUfp0ndGhem6PjqqRBc0etSP81NXG5Trl7be7fXb6tsfkwKxT1xdewtpBJ0eXHzKvONQBfdWMk2edWYiyQbi4otssGVM2eAbrS2Zcfp1XqKhYP1hJUu18h54vGLcMVlDV7xhzC1EzrSbA41pDg5yDYdLC-t5L263HCi-8efESt9Ganz0SYnUC54WkaDQyTaNS605nZJo6-4oCAEuYFYI1wmN9Zvss4mEJaMdfgHerKq1x8sMJ1ibXHoMG5jIFRyPzlG3t7qZtMSGRFGqlTPkOzFGd4rlKy0AxQ9gRmfNkhZKC-TcBAemc=w1116-h837-no
NrnXDpMeRUzkk-a6QDbleeTnV1T55T4d-SPm3jOESP92Hhq0g33WyfHsttjd9TqCSoUBzy59CqDsf8fkjkaquaTgoW6xrYHQrfc--pUYUidgiOz_eC8RkONSBGCLD2huH_UvsPZUgEI1v8bJYoncby4DcbB8ardwpaUFYbWj85f1tMYdFv2-AOq_SsPfk7bscw3-icfqArQe6iZrvVystwM0VTUG4D4U-A0pnt47Lh_8b5TpCuKHtcy7UGIpgVx2eYDZCC3VxjpY2Who8VNfAVyFpknORA1LSWmmUyDPCpqGU2lvpK5H8M0P6b3blvG0uMcbA9vk3Jml9UgAlPAXGj8hlmjETzFugPXUi_FGz9dhM59b4mS06D1hucObPZ_brcLJ2LC5lgKTGM2olP0tv78IsNjBSBRXqqbnUGEJU6ER8rEZVPdEj0Qbh9PGjOxNQ_EFl9OvxSaWoFODB38cwppvJD93Hle_WcxuZWh0sHkIgONXLZQAfGU8RDqvivQTmtqcAT3yNHwSHKoLraI3-UTHH2QcWS6FvrDjndHJg4S82nxTZ7k6dVLUBv04sfxJdDVD-wqJb5IkjdhInM2kb4IpsVsJpqs=w1116-h837-no
I made a small cut on the Leica hood to remove the clamp - it also allows the screw clamp from the other hood somewhere to go.
Check that the filter glass is going to fit inside the hood, there is a lip that normally stops the Leica clamp from moving to far forward
dVRX_DhpMWyRYEMfkRea6jtEtPljQrr1cgegj-22m6_ciMgY_HE0-bcD6oyipFkdSMlLR24xILc1xggm_r7AHniVz9DDJ4ZPfoY5CFzRyD8HKyoysBjfgcBzF7shXyZv-_ar9jw9qwCk2cYcAVWi-zMxkEtgDu468EM0wtv83RSfSdxh4MQFpbHQP-dwzW-EWxOxJh6Ahjo2LlY5c64_0FZGxP9drqQT0eBEhc14TErZmLt2MK5cZiutfhMrewGyIEdQO2BvbGhm3UxBLDuSlhFGX3StBQNl6sQiqsi13VeBVogOY63JaWGpFzAMLPKr9J9Qw6rB3kkhOI7oIsS8faZF-tEY5exhmq48qWhrWOrbSY6N9nwnbeJdxewPASmxdmVWFumJYyz0WcghESyDDJPSFLTn22yZLwY7eV704UWlwDe1wFObx35FVHvKjcJtqhWtfFA4ey1Bqtb9g_iUvAooqr4IQVmqMDRTZ5ytVpXUzlY0Ijpty2ZRzb-UYNe__yj7BlVjI6QmKMbzgwRxT_maTnLQltPVHSO4Ml_d-J7o55OQaGbakKIpxo7nEgCBaTEkF5KLCIp1BSWeKU_M9weNT82EjjI=w1116-h837-no
I then filed down the brass clamp to reduce it's diameter to about 0.8mm larger than the ID of where it is going to fit. This makes it very tight so it doesn't rotate at all, and takes some pushing to remove.
I also filed the front face of the clamp flush (the lip in photo #2) - there is still a small lip to stop it sliding all the way onto the lens, but it is very thin. If it has to be removed completely, then the filter glass will stop it going on too far. The aim here is to have the hood the same distance forward as with its normal clamp and has the filter glass as close to the lens as possible. Here are all the parts ready to go - you can see the exposed brass where it has been filed.
pCiUx3Ui4KXnbILh4tYrGl6WwTLVxcpTu29_gFsctjoYml4skbuXhpNwMKJFPPuZAZblrOXrSvjJwBlND-bsiyMTi198d8cVUDQQ8RDRyVfvcqC9pvaI2Z0lWJVCYErlHW3Si9w4YDCTCsJUcUbBFDrpfFqjtdov7KFvQg3d2Pc0SD92EvLbLCGSqb8hKRk10QuhoQcQOQH-g0Xe4KhhN3TpD_HUMMKUijEr5iP3GXkh3SlAvCwNJEZmEwjCZ9RzqLyGMbzRz3c4Sz-AbZOXfx0dz1_MK53QBjZ1Zd7nA-b8Jwslb8FusFR-Kl_-R6LSuRSKJL0CLPPVOOUX_m3cZp9OtqXYyM7kiGFw0iMFmGzKqk0P1ErjQeIm8yp5BWV7Y9jumIRXvsvGHHG92EehfwHwVRxPerMQVh0BoKH249RiCK1X1cB7xf__ZrwywQqzsTRtAw5Xx99HpHjw5fCrYU4ksiRzDehiparKoqJ28aGpXAJLhoOQJ_lxWWLbG6lFcInElx_heorGn9XGw0dtAAI6inPlLn83C_rXhirYxj99Rj5zN17fHXw2WZkx_LDnCP_0E9fqPUReIjqldTZwh3n4uoiTR9c=w1116-h837-no
Assembled from the side - you can see the lip that stops the clamp sliding too far on This is very this and doesn't encroach at all into the field of view. I chose to put the screw on the RHS (from using the camera). Basically you can point it anywhere, just cut into the plastic. Down it interferes too much with the focus for my big hands. On this side it gets in the way when selecting apertures smaller than f/8 but otherwise is okay. As always, YMMV so make a choice. I don't think there is a perfect choice though (maybe up?!).
iRC0_GoKmkJwpZ1pS5wCMTe6gRbcCEjrc37iATmSTfmZzK3x-s_gON_x_aefbtJCQby5oiam1x235kdmpmQOcy6cyHI3q-TAatH9YiFlQXEDHrDohw_DOjFDDTDHhC_Y5rcJgun5fzL7OHYnH18qRmdqN6kFFiuhPZ-GVUrW_7jSRKQm8kakr1VaERxd8nJsWIq4wcE6xL69am9lSD6EDXGJ2lNOaB-A1yXggw0Z7X8ul7TGL0Y7UWpiflgH8f2onafRRkFZ25mff0lL3CBV1ItWgsM7rM6kuqQgz8AC3CMJXQDKaOlRNWe-aQuAeuBEsVxZAkad2TAskUWk2dtGy847C9BIa5mML0hnuBqdDnombm6GhE3Ba5Ag0Jhb8Rjqa0t6qzaXW9o3Cu-VL63eoyUXGyKv4nd3lHREsJvnBVVcbhh4I2Ril-Dq6OBKL7M2uTbtbPqivAj78JA6zYobtDVQRTscJt-yH_G3UQfv9Nx5nCumUpTjXDlNUq3aEJPZA4-frqJwHQpUj6cC_75br9SjrEYwx0cmjWLywvzzAlDVWa8OvHo8VFGtGRU7FKRpr6dUgmaTtGTSa-1049jnKFB6UFk17xI=w1116-h837-no
And mounted
6AaKFTSejFNf1ViWoCoJwMTzD5iIjyoz6IShIwQ8XpZ_VlOFyiUyTJPKyTwzKDDenDJkEAyW7POadOFIN46rXAUyupNkkd32_uXsPvwIlt1HHivgzzIf4DhUEcOrbAHSATkmKf3O2BE5E3OIDYoMw9C96xGJRrdIvFbttr9GeO8KUtzVOibAzl30sXmwLBFxAiOvrL7l42okAc8hG__hyh9McTEP8YiLsUSGAT3SN6uaKrsVTdPuGx6KTOfTmh80PYZTtyfpm88qDwEMoOJimF2XvVu_H6mF-nraKbm686EgOepdUH7LZWZo4EQ82ejH1p1FzNL2UCpxMLgdCx-ny9GOfWNsJj61vRtbLHdtBMolgUaY-41a5-y5OCWGzZylVsRPROItA-SjozOnItglZWavJXmZC2E0QRm3n8CuzYC2BbIGzfpBTKIyOod3JEATQ9pvFW3EvX7pDFpbcz_ZD3ykZbm0nhiUYVm0bID0BvaKxHaFGDTZAj7VF5eTO4YF3X5t46E-9Yj2KsQUoWSzj4ys4Z9dT77QO1KlUFb_xcE364df2ThbA6hXMbYdDiYQYyffICtrM9Q3fzzm2VMgpCw26hTQ8b4=w1116-h837-no
mAiPNWGztxiszKeVYt-3LBSyeBub3hLCuUvuLxEsBAtwR2XK5XZWtPaxpVMgOOweSfrQakVfOt6kFozRMh2IJVycvQzMV-PD9qDVNWPy88TqmW0Zakbc8svDfbshF11co0rt-UMHxsJLqfsbEf9cWCqV71flc68z4VABLWZK1eR2lN0jnncshgt5Ge5Wh8wVLlialiZSyFU85FxV0xT19hQoO7HJ2UEeOaOdYuoGbs6D14FJ1U0mKaOFEoHSLxKln6RTWlrdUdovzx0tVk-fepwKxbMKtDvJg--Wz-58PvjGypATOb5JsudmZNfrkC10TygnkGcxPOWuOohM2szoFkFTRV8UI8sPC2qhtC0aJXd8TSrgkG3J9IrqzCr3byWQsEI7y8zIRJyURZ48vIhgST8pqdQ0UwP8dtAnYE0Ykrtez6ikj7bgx-wTo7OP1OM_R-0GD8pDRvM89LAhQKv55oXKotor0X7N-iCbqNKlGSAhKZMWZYJi30cUq9peEpL2-Hr7LeD2h5zpiPaNB9URlk6QBjuBmX-Gb2bttrf5U7ZdPcTw_RJgUMVefwgyKYrnR0V3LIG2FVHQvlwaToHHo_7glD0gm5c=w1116-h837-no
I've done some test shots to test for vignetting, but I haven't developed the roll yet ...
A bit of matt black paint wouldn't go astray!
If it works, I'll make another one with a UV filter and just swap when I need to. The whole lot (not including my time!) cost about A$100, so about the same as a Leica Series 7 filter.
Anyway, that turned out to be a long post!
EDIT: I know that the photos are rubbish, my only digital camera is an iPhone. I understand the irony of posting such bad photos on a photography forum 🙂
Very, very helpful and interesting approach to this Summilux problem. I was one of the persons trying to mount some filter with a rubber o-ring into a 15256 hood but gave up on that solution because no filter changing possibility.
Yes, I remember! I believe you were using plumbers tape to stop the rotation and getting some coner vignetting from the filter?
Alas the problem of swapping filters easily is still not solved...
Initially I'll keep a yellow filter in this hood, and use the 12504 hood for alternate filters.
I had no problems with rotation of the hood but dark corners from the to far filter position.
After taking, developing, and scanning a whole bunch of shots of a white wall I confirm that I see no difference in terms of vignetting between my hack, the 12504 round hood, and no hood.
I can't believe how boring that was. :bang:
Another Hood Solution
Hi all.......this has been a reference thread for me so I thought I'd post the solution I found for the hood question.
Kodak 42mm Series VI slip on adaptor with a Leica UVa Series VI filter dropped in. These adaptors were silver alloy but I've sprayed this one matte black to match. Changing filters is very easy and it fits very well, no movement at all.
Adaptors are hard to find but they are out there.
Pictures.....Before & After
Here are the pictures before & after. I'm testing for vignetting but it should be fine as the filter is wider than the front of the lens. In fact, not too far different to the 12504 hood I have.
Anyway the test roll across all apertures is souping now and I should have my answer shortly.
Nice, I wonder if you could fit a hood to the adapter..?
If it's compatible with a Series VI front adaptor ring then should be fine. I'm also hoping the relative straightness of the ring sides will act as a bit of a hood to stop stray flare. The 12504 frankly is not very good at this at all.
Oops, sorry, wrote too soon. Slight dark corners wide open and about 2 stops down after scanning the negs. I may have a solution for this though.
I'm going to try a thinner front ring on the adaptior and run another roll through.
Bear with me, I will solve this!
I'm hoping! It looks like the best indoors no hood protection option for keeping the whole package small. But it needs to work wide open.
I've seen similar filter adapters from tiffen, any different to the Kodak ones?
Having looked at the 12504 widths and compared to the Kodak adaptor I think it's the width of the series VI filter that is causing the problem. The Kodak base width is exactly the same as the 12504 but when the filter is dropped in there is some overhang. I'll see if I can find a thin screw in filter for the front of the adaptor and avoid the drop in altogether. I'm hoping a 43.5mm screw in filter will work.
43.5mm doesn't quite get the threads. If I taped it it might but I'm not keen on that.
Anyway, I've just found the series VI front width and apparently it is 44mm, however it would appear 44mm clear filters do not exist at all.
Next solution, 44mm step up ring to 49mm and fingers crossed. It'll still be quite compact.
Will keep you posted but the step up ring is going to take a little while to arrive.
Intriguing...
