35mm through Yashica 44A
ajishc
10:46 AM
HI All.
Last week, I bought a box of 35mm film (Fujifilm Superia X-tra, 400 24 exposure) and ran it through my Yashica 44A using the 127 spools.
Got it developed C-14 and scanner the negatives through V500. I had to adjust the contrast to get the right color.
All taken at f/16 and 1/300 secs.
It took some work to get the 35mm rolled onto the 127 spool and get it loaded into the camera in complete darkness of my closet. I rolled and glued thin strips of paper on both ends of the spool to get the 35mm positioned in the center of the spool.
Ajish
Was much easier on Rolleis with the Rolleikin adapter. Your results are reasonable. The first and third are the same frame, with some flare in the upper left corner.
