goamules
...mostly made of bakelite and aluminum? Can you tell me what parts besides the knurled focus ring is not brass? The entire body appears to be chromed brass to me. The important helical is pure brass. But what's wrong with aluminum anyway? Most lenses are aluminum for the past 40 years. Are not Noktons?Compared to your 1.1 Nokton, the Canon 50/1.4 LTM will have less resolution at all f stops. It's single coated and quite sensitive to flare and barrel distorts noticeably. Also, at medium f-stops (2.0 and 2.8) the aperture has "Spikes" which you will see in the pictures in the OOF. And due to over correction you'll see slight donut oof ellipses wide open with high lights in the back ground.
I've cleaned several of them, they are mostly made of aluminum and Bakelite (spell?), and a couple of smaller brass rings.
But you are comparing a modern, computer designed Voigtlander to a 1956 Canon, from the era of Elvis and cars with Fins? We should just stop here, and realize these lenses are generations apart. The Canon costs about 1/4 to 1/3 the Voigtlander, so for someone on a budget, it may work out for them. The OP didn't sound like he was on a budget though, he was on a quest for something better than a new, leading lens. I think that will be hard, and the old Canon won't do it, on retrospect.
