5cm F2 SUMMITAR SCREW
R
Roberto
Guest
Will this collapse into the Bessa R? Or will it touch the shutter curtains?
Stephen are you out there? 😀
Rob.
The Summicron collapses on my Bessa R2 without problem. The Summitar collapses deeper. I do not collapse it on the Bessa, seems too close for comfort.
You still need extra clearance- the shutter blades of the R2 are not flat. They have "little struts" on them. Does not take much to ruin them.
rolleistef said:
set the shutter on B and collapse the lens to check whether it will damage the curtains or not?
Err... maybe with a "T" shutter setting (that the Bessa does not have) but I will never do this with the "B", I'm pretty sure that my finger will slip when the lens is collapsed and the shutter will crash on the barrel.. 😱
Trying it out with B is even more dangerous than doing it with the curtains closed. With the curtains closed, you can feel if you hit anything. With the curtains opened, you can have a lot of bent metal and/or scratched lenses before you know what hit you.
If the lens hits anything, it is likely that it is the internal baffles and not the curtains themselves. That said, I wouldn't risk it. Plenty of nice non-collapsing lenses out there (many of which are identical to the collapsible versions).
