60mm lens software question
clicker
9:35 AM
I am having difficulty loading the latest version of lens software to my 60mm macro.
I have loaded 2.0 to the camera and next I downloaded the lens upgrade to a clean scandisk. When I then insert the disk into the camera it shows the camera upgraded but not the lens.I then select to upgrade the lens using the software on the disk.
I get a message that the software cannot be found on the disk yet when I view the disk on my computer it is there.My 35mm lens upgrade worked fine, any ideas would be appreciated.
I think the problem with this update is that they used the same name as the last update. When I downloaded the update it showed as "filename".dat(1)
I erased the parenthesis and it worked.
Also don't forget to select the update lens option.
HTH
James
