Brett,
I dug out my wind knob back, and ran a dummy roll through, using the duct taped spool. The result is eight evenly spaced frames. I am pleased.
I gave it four winds of duct tape, figuring that would do it.
Next I am going to try this method with my old old Plaubel Makina backs. Those are notorious for uneven frame spacing. It should work!
-Dan
DSC05849 by
Nokton48, on Flickr
Same duct taped spool used in 6x6 Plaubel Makina #3 6x6 roll back. Result is twelve perfectly spaced frames.
DSC05851 by
Nokton48, on Flickr
Looks like you are good to go now! Well done.
I don't know much at all about the Makina backs, but with the Rollex, I suggest inspecting the area around the inside of the wind knob where it rotates inside the housing. I noticed a few small metal particles there and wasn't particularly happy about that. They most likely were lubricated when new but my example had been unused for many a long year and was quite dried out. I used a combination of a dab of moly grease and a speck of oil around the inner boss. Pull the knob out as if to remove or replace the film insert and make sure everything is clean and free of dust, too. After exercising the mechanism for a few minutes I wiped any excess lubricant off from around any exposed surfaces (there should not be much of that if you take care not to be too liberal). It winds a bit more smoothly now, and no longer wears, either.
It's easy to replace the light trap seals. There are about half a dozen screws visible in the plate around the film gate; removing these with the magazine inverted will see the plate detach leaving the small rollers sitting in their slots. These do not run on pins, they're a simple interference fit in slots between the body and the plate. After cleaning with lighter fluid and gently polishing the running surfaces with some Autosol metal polish and removing the residue of this, a speck of oil at each end (I used my usual Moebius 8030) will see them actually rotating in the slots as a film runs over them, as opposed to the film being dragged around them. The light trap seals are strips of velvet on a decently thick backing. It was quality stuff and I'd rather like to locate something like it, most shop velvet has a fabric backing far too thin for sealing purposes.
If the velvet strips in your Rollex aren't too badly worn you might be able to extend their usefulness, at least pending procurement of suitable replacements, as I believe these are no longer available from Linhof themselves? You could, potentially, do this by gently peeling them out of their slots and reversing the installation direction (if their condition suggests this may be beneficial, it may not) as well as shimming underneath them to compensate for the wear with paper or metal foil. It's easy to over adjust this, so a trial assembly to see how smoothly the dark slide inserts isn't a bad idea. The seals or their replacements can be re-glued into position after cleaning the slots with some contact adhesive.
My whole Linhof kit had been unused for many years. The case had rolls of Ilford FP3 and Ortho that expired in 1961! It was all still in pretty good condition, (you can see some photos of it and information about what I had to do to get it working, again, in
this thread from last year) but dark slide of the Rollex had some corrosion present in a few places. Using it as it was wouldn't have done the light seals any good, so I spent a half an hour or so attacking it with Autosol and a cloth. A few pits remain but they don't matter, as long as the high points and rough edges are removed it will still work fine.
My seals were pretty flogged. The back had been stored with the slide in place and decades later they'd compressed enough to produce visible light leaks. (I think that generally, whenever one stores an unloaded film magazine it's not a bad idea to keep the slide removed, it is apart from anything else easy to tell at a glance that one is unloaded, this way.) My wife does a bit of knitting over the winter months and during a visit to one of her favourite wool stores I noticed small sheets of black felt sold for a few dollars. Of course I grabbed a few immediately as they can be so useful for various camera sealing applications. I cut some of this to size and replaced the original seals. It's not an ideal substitute--velvet would be better, because the felt is more susceptible to fibres being cut off when the slide is inserted. I'm fairly careful not to angle the slide when inserting it, and it has not been a problem to date but I'm still keeping a bit of an eye out for a similar material to the original seals.
Brett
