Nokton48
I think i read 150 ft as 15 when i looked, oops that actually looks good. I need to work another week as ive only got £100 pounds saved so far.
I did have a crazy idea as Im being given a paper processing machine which uses rollers and a temperature controlled system of running paper through it, provided i cleaned the rollers and kept the lights off I could maybe run film through it with a bit of trying. It would probably result in scratches though but it might be worth a try.
Hi Jake,
If you have 100 British Pounds, then you have $128.79 US $$$.
So you already have enough. They will take an offer; they have had it for a while. Offer them $110 US $$$ (or less) and they will prolly take it. 😀
This is the same film Nik N Trik are respooling to 120, see the pix above.^^^ Respooled they are asking 10 Pounds per 120 roll! 🙄
I just got delivery of a roll of Plus-X Aerographic 2402 dated 2010 from Bennini in Italy. I think I will load it into my Plaubel Makinas. I also have 150 feet of this film, if I like it, I will start using it in 70mm🙂
If you want some color, the same seller has ten rolls of this stuff. I got a roll from an aerial company in Florida.
http://www.ebay.com/itm/AGFA-AVIPHO...959990?hash=item466299d736:g:Am8AAOSw42JZB0g2
