Nokton48
Cal Rollei 400s Dianfine High Key Lighting by Nokton48, on FlickrAnd here are Cal's Rollei 400s High Key tests in Diafine. Also look good.
Cal Rollei 400s Dianfine High Key Lighting by Nokton48, on FlickrNice Cal, have someone else post images so you can still claim ignorance of how to post images AND keep your I've never posted images streak going...
Joe
Cal's Kindermann 70mm loader by Nokton48, on Flickr
Here is Cal's Kindermann 70mm Film Loader. What a cool unique item. And so are his two Baby Technikas.
Hey Cal, Can you spool cartridges with that thing, or just load dev reels?
Cal,
For many years I have developed Tri-X and XX together in the same tank, with good results for me. Of course I am not using the same developers that you are using, but the concept is the same. Often I will develop 35mm, 120s (two to a reel with JOBO), and whatever else I have, like sometimes 16mm slit down from 35. It works for me. As you know my preferred brew is Legacy Mic-X from Freestyle.
I'd like to see that early Kindermann 70mm loader. Does the one you have fit you Nikor reels OK? They must have had different versions (or vintages, as you say).
Job is mucho mucho crazy right but looking forward to burning more 70mm when I have the time.
-Dan
Kindermann 70mm Loader 4 by Nokton48, on Flickr
Kindermann 70mm Loader 2 by Nokton48, on Flickr
Kindermann 70mm Loader 3 by Nokton48, on Flickr
OMG OMG OMG!!! Look what Dad got me as a gift!!!! Nikor 70mm developing tank!!! These things are IMPOSSIBLE to find!!! #70mm #ilovefim #ishootfilm #mediumformat #nikor #film #family #dad #developing #winning #work #chemistry #116 #616 #yes by Stone, on FlickrHere's the Nikor tank to go with your reels
Notice the homemade SS double 70mm tank That would take a gallon of stock
With the Nikor the top is in the center of the tank. I think it's a Nikor 35mm tank top and lid.
Like the Kindermann the top is prolly removable and disassembles into pieces
I wonder how I might adapt a stainless steel pot or make a tank... l
I think it would not be terribly difficult to create such a thing, with the right resources. These 70mm tanks utilize removable standard 35mm tank tops and lids, so you could adapt something. An old Patterson or Kindermann 35mm tank could be cut down and dropped and secured into a plastic or SS pot. Could be a one or two reeler. Could be soldered, welded or otherwise attached, whatever you discover works best. This would give you something you can't buy in the commercial marketplace, off the shelf. I like to do custom stuff like this. You should persue it.
-Dan
Well today I finally pulled the trigger and purchased my a70, some cassettes and 100 ft of kodak xx aero film as well as an NDT dental reel. After faffing about for ages telling myself id order some things or do something first after another london fashion week spent changing a12 film backs it will hopefully be worth it
If It's Plus-X Aerographic 2402, then I have two 150 foot rolls of it myself. So perhaps we can discuss with each other the best way to develop.
Also I have a respooled 120 roll of 2402 I bought from Nik N Trik. That will be good for testing.
Jakes Super XX 70mm by Nokton48, on FlickrJake,
Here is what you ordered. It is Kodak Super-XX 70mm. This is type II perferated film, so it will go through your Hasselblad A70. I've never shot any Super-XX, although I think I once had a box of 4x5. It was great film. When you get the cassettes I will be happy to tell you how to load them without any hassles. Once the cartridge is loaded in the dark it can be handled and loaded in subdued lighting.
