Highway 61
Revisited
Hmm. Close to perfect, but not quite. An Apollo-style winding lever would do it. 😎The perfect S3 for shooting
Kirk,
If you call Nikon USA they most likely will have NO idea what camera you're talking about. I called twice when I had the same camera as you and couldn't get a person who knew anything about the camera, let alone about the parts I was asking about (such as a replacement baseplate). Don't be surprised if they keep thinking you're talking about the little old S3 P&S from a few years back.
Kent
I did a DIY on a Leica MP shutter curtain with a toothpick and a tiny amount of "liquid electrical tape" (e.g. from home depot). Apply the tiniest amount you can apply from both sides of the shutter and leave everything dry open for 24 hrs. You have nothing to loose. You can't use it as is and have to repair it anyway. If your repair also works, you have save a couple of hundreds. The stuff will be permanently elastic, is black and totally light tight. You will need a bit of courage and a steady hand though, good luck. Worked for me.
The Canon P shutter curtains are made of steel foils. As a result most of them got wrinkles from dragging film leaders and operators' lousy fingers but I wonder under which circumstances they could get some pinholes in them. Could you tell us more about that ?I have used same DIY technique on the shutter curtaiins of a Canon P. It works and it lasts. Why go for a major overaul when a basic DIY will do.
I was appalled to find that my minty black SP 2000 now has a hole in the shutter curtain. I need to have it replaced.
1. I can't use DIY advice (way too clumsy). I need advice on who in the US will do this well. I've had Essex work on an S2 and thought they were a bit careless (instructions overlooked, and a new light scratch). I know that DAG is willing to work on Nikon RFs, but I doubt he has Nikon parts. Who might be the most skilled/reliable repair person with a replacement shutter curtain?
2. I understand that a lot of SP and S3 parts are interchangeable. Is it possible to have an S3 cloth curtain replaced with a titanium curtain?
3. How-the-*ell doe this sort of thing happen? The hole appears as a pinpoint at the bottom of negatives (and with a bright flashlight at the horizontal top); also as you might expect as large flare spot on some negatives. I can see a very slight abrasion at the site of the round pinhole. I haven't been pointing the camera at the sun or leaving the body without a lens on for the cat to play with. The only thing I've recently done differently is to mount a recently-acquired CV 25mm S-mount lens on the body. There's a hole in the first frame with that lens and none that I can see on previous rolls. A possible cause?
Advice greatly appreciated,
Kirk
.....The Canon P shutter is more fragile (you don't see crinkled Nikon titanium shutter curtains although they've seen the same amount of dragging film leaders and operators' lousy fingers).
.....As a side note: metal shutters will get holes, too.
Titanium or stainless steel shutters? I asked about this years ago and was told it was impossible to burn a hole in a titanium shutter (though I've heard of cameras with pinoles in their titanium shutter curtains).
Jim B.
Yes, very probably.I wouldn't go quite that far. Year's back, when I was doing the used camera show circuit, it wasn't unusual to see a wrinkled Nikon F shutter. If you don't know what you're doing, or are in a hurry, you can wrinkle a titanium shutter while loading it.
Jim B.
