Bill58
Native Texan
Wouldn't it be interesting to see the low/ no light side-by-side results?
Pherdinand said:it's not a fair test. These are two different category/purpose cameras.
IGMeanwell said:Well I by chance have some Ilford Detal 3200 shots from the Natura S somewhere and I own the F30
So if you really want it ... I can supply samples; but your going to have to wait for a little while
and the samples won't be of the same subject
Nick R. said:It's a weird comparison. You're comparing a digital sensor and its accompanying electronics, which is unique to a certain camera, to a film which can be used in multiple cameras.
Issy said:Non-sensical unless you specify what film. (e.g. load up the Natura with an old roll of Kodachrome 25, and compare) -- forgetting about the 24 vs 35mm equiv field of view.
I will say this, though.... when the internal noise algorithm kicks in on the F30 at high ISO, the effect is almost like "stained glass", or "melted plastic".
Assuming a compare with high ISO film (1600/3200), I would rather have large, well defined grain ("pebbles"), than the "muddy" look (all other things being equal)
Case in point: http://www.photo.net/bboard/q-and-a-fetch-msg?msg_id=00GuuP&tag=
Issy said:Yep. My first comment was to the original post.
Referencing your images in #12, though, IMHO I still prefer the grain vs stained glass.
What did you rate the Delta at? 1000? 1600?
ampguy said:I think any kind of comparison is going to be apples to oranges, but would also even be difficult controlling with 2 film cameras due to development and scanning variations.
I have the F30 and have taken some photos at 1600 equivalent that have similar facial grain to the one in the left photo (natura?), but also 1600 photos on the F30 that don't show it so I think the same subject and exposure conditions are a critical factor that needs to be matched.
And yes, the lens on the F30 as it extends, does increase the min. aperture, making shallow DOF photos much more difficult than with a film camera or DSLR with < f2 aperture.
I really like the F30 having used it only 3 or 4 times, but it's a different type of beast than a film camera or even DSLR. See my review in my blog.
