Roger Hicks
But at that point you need to 'throw away' a good deal of the potential resolution of the imaging chip, using it only for the viewfinder and not for the imaging area. Looking through the finder if my M9 (the nearest Leica to hand) I reckon that no more than 2/3 of the viewfinder area is occupied by the 50mm frame. In other words, to equal the 18 Mp resolution of the MP you'd need a 27 Mp sensor. Who is going to go for that?Still, with the increase of EVF quality it should be no biggie to create a rangefinder-like focus system that is mostly digital-based.
First of all a bit of understanding the RF experience: when focusing a Leica, it's in fact two different methods you are using at the same time. One is the superimposed images, but the other comes from the sharp-edged RF patch. Line up the objects inside and outside the patch and you're in focus. This aspect is what is needed for a digital RF mechanism.
The X100 projects digital data in the optical viewfinder, right? So, why not take a square bit of the sensor image and project it in the middle of the optical viewfinder? It does not have to be superimposed, just the sensor image! When the camera is in focus, that little square will be in focus, and it will line up with the optical image.
Along with that it'll be quite easy to have framelines in the viewfinder, like any rangefinder camera.
I really cannot understand why no manufacturer is getting into this. Like I said, I presume that it is a much cheaper to produce RF system that will sufficiently mimic the Leica RF.
Unlike you, I find it very easy indeed to see why no manufacturer would bother to make a poor, electronic imitation of an optical rangefnder.
