alexz
The preface quesion:
In regard of using standard commercial 36-frames roll (say, Kodak Profoto 400BW) - what does mean trying to use the last 1-2 spare frames ? I.e. once reaching frame 36 (according to the counter), I advanced to the next one (37) - apparently went OK (at least the crank didn't stack), shot, the advanced to the enxt one (38) - went OK either, shot...what should I expect ? How should I know I reached the last frame indeed ? Can I expect the film advance crank will stack trying to advance after the supposedly last frame on the roll has been shot ? Can I cause a camera damage trying to squeeze another 1-2 frames out of regular 36-roll ?
Now to the issue:
Today finished Kodak Profoto 400BW roll (regular 36 frames one), then made an endeavor to rewind the film by usual procedure - (rewind lever to R, then unfolding the rewind crank and turning it clockwise according to the arrow direction). After about one or one and half revolutions it got completely stack, even applying some moderate force did not help. Several attempts to release it and turn around failed.
Finally I broke up, set up my film changing tent (I use one for 4x5 holders loading), opened up the camera. The film felt OK in the shutter window, however I do not remember feeling the bulk of the film wound around the take-up spool. I played up gently trying to release the film on the side ot the take-up spool, then made a half revolution of spool of the film canister to check film's movement - it did. The canister remained inside the film chamber on its place. Closed up the camera, took it out of the changing tent and tryed the ordinary film rewinding procedure - after some very short tension turning the rewiding crank, it begun revolving more freely so I felt there is unlikely film left of the take-up spool. Opened the camera - 😱 the film turned out to be rewound completely inside the canister ! - this bearing in mind that it took probably 5-6 rewinding crank revolutions...
That lead me to the conclusion that originally, loading the film few days ago it was unlikely caught up by the take-up spool, i.e. somehow it appears I failed to load it properly, even though I remember letting the leader between the posts...
Which means I have some presumably very desirable images of my family that went to the dust due to my stupidity...:bang:
However that did not reveal the reason why the rewining cracnk has stack then...weird...
Now, decided to give another try to that Kodak film - picked another Profoto 400BW roll and loaded one paying attention to the procedure. Guess what ?
Closing the camera and advancing the film towards 0 on the counter (presumably two frames) - the first one was fine - advanced and shot, Now advancing to the second one (towasrd -1 on the counter) - the advance crank has stack in the middle and couldn't finish the operation. Tried rewinding operation, was able to made about half revolution then it stack up also. Had no choice but open up the camera - the leader appears to be inside the posts of the take-up spool but no film wound around the spool (perhaps I pulled it back to the canister while trying to rewind it slightly). Made another endeavor - loaded it up, closed, first advance was OK, the second caused similar problem. Well, once again opened up, now took the film out and discovered a broken perforation hole at the upper part of the camera. The tiny film part of the broken perforation just above the hole almost got into the shutter, i.e. at the edge of the shutter curtain and its frame. I suspect this is what caused the film advance operation (and subsequent rewidning attempt) to stack up deadly. The question is what caused to the perforation issue...was it by the camera somehow or probably a bad roll of the film ? Go figure....
Anyway, reloaded the camera with Fuji Sensia - went OK, now on my 25th frame, hope it is fine inside...
Any experiences with similar issues ? What may cause such kind of issues ?
Any thoughts ?
Thanks in advance, Alex
Now to the issue:
Any thoughts ?
