Still testing with great joy my new MP. Here are some thoughts:
- I am mainly a 50mm-90mm user. So the thin margins around the 35mm frames aren't a real problem for me. But I found a work around anyway, not very original, but very useful considering my needs. On my IIIg, I was using an ultra small 28/35mm mini finder from voigtlander (got the idea from the very great site of cameraquest). Doing this, I realised that the margins around the 50mm frame of the IIIg covered actually already the 35mm area. Of course, that leave me with no margins as far as 35mm goes. But when compacity matters, I found that I was doing OK with the sole use of my IIIg finder. Then, I tried the mini-finder (which is black painted) on the MP… And I must admit that this is a great combo! Lot of space beyond the 35mm frame, and also a valuable 28mm frame, in a super small package. If you don't want to trade the 0.85 magnified superb finder of the MP, then I think the mini-viewfinder is the perfect ticket. I got mine from cameraquest, that has still some stock, I think. But it is a sold out item for a long time everywhere else (was not able to find one in France nor in Japan).
- on my new MP, using ltm lenses, when driven to infinity, I found the lens movement becomes harder just before arriving to infinity. On the Heliar 50/3.5, Summitar and Summicron 35/2, all lenses with infinity locks in their ltm format, it demands more strenght to unlock from the infinity position. Nothing very bothersome, but still not as smooth as on a screw mount camera. I even tried with an old 9cm elmar, and regardless the absence of infinity lock, the lens movement clearly get a bit harder on the last few millimeters toward infinity. I ask here and there, and found this was not completely normal. sing the camera more and more, this phenomenon tended to weakened, and it turned out to be an issue with the telemeter arm being set "hard". Leica told me that I had 2 possibilities: a. I could wait, and it will in the end "probably" just go fine or, b. I could have my telemeter checked, and if I want, adjusted in one of their booth in Paris. Of course, I will have it checked this Friday morning, as I want to make sure it is not something else.
I never had a "new" Leica. Only used ones. If this is linked to a kind of "just out of factory" hardness, well, OK. But as it is not always the case with new M, I will make sure of it, and will let you know.
