Adox CHS 100 II film is back!!
You didn't answer my question. Could you afford 800$ of film and family?
I have two kids, one about to enter college. My son's private school's tuition is more expensive than 80% of the USA's universities.
So yes, I can afford film and family. I can afford cameras too. In my camera bag are three Fujifilm rangefinders: A GF670, GF670W, and TX-1.
So, it is simple choice at ten bucks per roll. Stay single or quit from film.
Are you, guys, single?
Ko.Fe. It is one thing to not be able to afford it because money is very tight. Then by all means, photography is luxury. However, it is another thing if you have the money, but your wife thinks your hobby is a waste of time so she thinks you shouldn`t spend the money. Then a new wife is needed. $700 a year is not a lot to spend for photography unless you really just can`t afford it. By the way, don`t you have a few leicas and lenses?
Ko.Fe. It is one thing to not be able to afford it because money is very tight. Then by all means, photography is luxury. However, it is another thing if you have the money, but your wife thinks your hobby is a waste of time so she thinks you shouldn`t spend the money. Then a new wife is needed. $700 a year is not a lot to spend for photography unless you really just can`t afford it. By the way, don`t you have a few Leicas and lenses?
Very well said.
Even in all ULF formats up to 20x24" / 50x61cm!!
And that all over the year (not only once a year like the Ilford ULF programme). You make an order and then it will be made for you.
Cheers, Jan
Wow, who would need that gigantic negative 20x24
Btw, it is always good to have new film.
Sent from my iPhone using Tapatalk
Ko Fe can fend for himself but I think I'll keep my own counsel when it comes to my wife and family.
Hi guys,
Christmas surprise by Adox: Their wonderful CHS 100 II film is back:
http://www.adox.de/Photo/chs-100-ii-sheetfilm-available-again/
It is already available in sheet film. 35mm and 120 are coming a bit later.
This film is coated on their modernised coating machine in Marly (former Ilford Imaging Switzerland, bought by Adox in 2015).
You can get it in all standard and non-standard sheet film sizes:
https://www.fotoimpex.com/films/sheet-films/
Cheers, Jan
After a look through the options it appears that us whole plate shooters are still out in the cold. At least Ilford keeps us in mind during their yearly runs.
I wasn’t giving him or you advice. I was just generalizing. If photography is important, you’ll figure out how to do it. A Leica is too expensive for some, a $10 roll of film is too expensive for others. I am of the opinion that your wife should support your interests and vise versa. Life is too short to be unhappy.
You will probably also can get whole plate sheet film from Adox: Just ask them. AFAIK their sheet film cutting machines are extremely flexible and can cut any format you want.
Cheers, Jan
+1.
Very well said.
Cheers, Jan
For what it's worth , in B.C , Canada there's pretty well no film available that's less than $10 a roll ( and our taxes up that ~14% ) . But I'd sure like to try any of these slower Adox films 🙂 , is Santa listening ? Peter
I read here that a 36-exposure roll of Tri-X cost $1.15 in 1957. I don't know if that's true; I wasn't around then. But assuming it is true, that works out to $10.27 in 2018 dollars. B&H has Tri-X for $5.79. Not bad!
Just in time as my stash of Fomapan 100 is getting low. Quite a bit more expensive than Foma though, actually equaling or exceeding FP4. Not complaining, just saying.
Due to my results, CHS 100 II surpasses Fomapan 100 in all parameters: Sharper, better resolution, finer grain, better characteristic curve, higher effective speed, better AHU, better QC.
In comparison to FP4+ CHS 100 II is sharper and higher resolving. But FP4+ has a bit higher speed.
All these characteristics have little meaning in LF.
You mentioned QC - You found Fomapan to be poor in that regard in LF? So far I found no defects with Foma films, one exception was Fomapan 200 in 120 showing micro scratches (a well documented flaw at the time, adressed and amended).
Maybe not for you.
But for me. And I know from lots of other photographers that they do care for that, too.
And this film will be available in 35mm and 120, too, next year.
Yes, unfortunately I have had several different QC problems with Foma films in the past, like pinholes, black spots and converting problems (120).
Some friends of mine and members of our local photo club, too.
You get what you pay for: At such very low prices a manufacturer had to make some compromises in production.
The reason why I loaded up the truck ^^^ (see my photo above) is that PhotoImpex seems to charge 35 Euros for shipments to the USA as a start. Or at least that was my experience on my initial order go. So I ordered a lot of film, and the shipping was not much more than 35 Euros, and I got the film that I could not get anywhere else at the time. And the price per box was very reasonable, due to the quantities ordered.
6.5x9cm and 2.25"x3.25" sheet film is not easy to find. Choices are very limited.
Merry Christmas! 🙂
Merry Christmas! 🙂
I wonder how much BH or Freestyle would charge me to get some Ektar 4x5 over here? The film is much dearer in the EU (58 EUR vs 37 USD for a 10 sheet box!)
