Calzone
Gear Whore #1
RECENT DEVELOPMENTS:
I have to order more paper and ink after having bulked up on 330ml to start initially, mostly mid-tones, to keep stocked with ink. Ran through 400 ML gloss overcoat already and I'm on my second 400 ml. I had reordered 200 sheets of 8 1/2x11 Jon Cone Type 5, but I soon discovered that the prints really open up at 13x19. Oh-well. While Jone Cone's inks might be less expensive than Epson's OEM inks, my experience is that with Peizography you might be utilizing more ink to make a print. About every two weeks I've had to top up my carts to avoid the risk of an empty cart. Once came really close.
13x19 is a good size to print on 17x22 for exhibition prints because stock frame sizes are 18x24 that allows for exposing some additional border in a mat and then allow for a generous border generated by the matte. Printing a different size will require costly custom framing if exhibition is your goal. Dealers and collectors like generous boardes to allow for museum framing (archival).
I learned that air drying and printing the "Gloss Overcoat" 24 hours later instead of forced air drying for a few minutes provides a more satin/less glossy effect. My thinking is that the GO soakes more deeply into the paper when the print is fully dried buy the 24 hour wait. Also this seems to effect the contrast and tonality where an air dried print has slightly less contrast and added warmth over a forced air dried print that is glossy. No clear winner here, but I kinda like the satin of the air dried print due to the lack of glare. The GO layer is almost transparent and is almost invisible, even on a white border.
Cal
Cal
