david.elliott
I agree. Nikon is definitely the easiest route. And from a compatibility standpoint, with what I currently have, it is the only option that makes sense.
I really do like my 105/2.5 and the 24/2 lens. I am just so disappointed in the 50/1.8 though, particularly after using my 50/1.5 cv nokton. The nokton outclasses it in every way.
I'll look into the CV lenses. I think they might be outside of my budget for now though.
Very cool - I like how you use the OM2n. That's neat!
KEH seems to have spotmatic F bodies. And they turn up once in a while on the pentax forums too. The open aperture capable lenses sell for significantly more than the stop down lenses. That said, they're still pretty darn cheap compared to OM and Nikon lenses.
Quite the pickle. So many options.
To quote a Mary Hopkin song, the horizon is open.
- Nikon: The easiest route, since you have a D70 body and a few lenses. Problem is, you don't sound all that enthused about the glass you have. You could buy some F-mount CV lenses, as well as that F3HP body (and, yes, you do want the HP: way back when, I had two F3 bodies, only one of which had the HP finder; the other finder drove me nuts after a while, so I eventually changed the finder on that one to HP as well). Means spending a few bucks on glass, but I'd bet you would love the results.
Of course, if you're willing to ignore the extra bells/whistles, F100s are pretty cheap, too.
- Olympus: My sole remaining SLR is an OM-2n. The bad news is that the VF doesn't have much in the way of eye relief for the bespectacled among us. The good news is that, to me, just about everything else is fine. Love the compact size, control layout, and general robustness of the body. I basically use mine (in conjunction with a Sigma 21-35mm zoom and VariMagni finder) as an ersatz miniature view camera, so it spends most of its time on a tripod.
- Pentax: If you want full-aperture metering, there's also the Spotmatic F. But, (1) you're still dealing with a system that relies on a mercury cell, meaning you either find a way to get hold of said batteries, or (more likely) have the camera modified and adjusted to use silver-oxide cells; (2) in order to take full advantage of the F's metering system, you'll need to stick to late-model Super Takumars, which were made with the F/ES/ESII in mind; earlier models will still require stop-down metering.
And, Spotmatic Fs aren't the easiest bodies to find, either.
Good luck!
Barrett
