philipus
ʎɐpɹəʇɥƃı&
Are there any alternative hoods that fit the 2,8cm Hektor? The intended hood, SOOHN, is a very expensive collectible.
Thank you in advance
Philip
Philip
Mr_Flibble
In Tabulas Argenteas Refero
A36 clamp on filter, with the filter glass removed and a tube glued onto it?
I recall someone was 3D-printing various hoods here on the forum a year or so ago.
Luddite Frank
I assume that the FIKUS adjustable would cause vignetting on the 28 Hektor ?
Rick's idea sounds like a good DIY - experiment with various card-board tubes or contruction-paper cones...
LF
LF
Mr_Flibble
It does, the FIKUS fully collapse already causes some vignetting on a 35mm Elmar (certainly with another filter between them)
Looking at the SOOHN hood I think you're right and a cone shape is required.
Bab8barian's idea will look more professional on your camera
I'll have to look into that, because I want a hood for my 28mm Hektor as well.
healyzh
28mm Hektor Hoods?
28mm Hektor Hoods?
Does anyone make a replacement hood for the 28mm Hektor? I have trouble stomaching a hood that costs nearly as much as the lens itself!
It's bad enough what a matching auxiliary finder goes for.
28mm Hektor Hoods?
Mr_Flibble
Not sure we've ever found a cheap alternative beyond DIY.
Malcolm M
According to my sources, the Hektor takes 34mm screw-in filters. Googling "34mm wide angle lens hoods" produces quite a few hits. There are few accessories so obscure that there isn't a Chinaman on Ebay selling them.
Mr_Flibble
$3.80 and free shipping for a screw-in wide angle hood, I'm game!
healyzh
Odd, according to the "Leica Collector's Guide, 2nd Ed.", it uses A36 filters. The "Leica Pocket Book, 7th Ed.", also says A36. I'll hopefully be able to determine better in a couple days. This is probably the difference between interior and exterior diameters.According to my sources, the Hektor takes 34mm screw-in filters. Googling "34mm wide angle lens hoods" produces quite a few hits. There are few accessories so obscure that there isn't a Chinaman on Ebay selling them.
I'm wondering if a SOOTF filter adapter might work, at least enough to keep my finger out of the photo.
Zane
healyzh
Hopefully that will work, it looks almost perfect. I'll check the inside diameter, once I have the lens.$3.80 and free shipping for a screw-in wide angle hood, I'm game!
Zane
Mr_Flibble
Yes, A36 is the standard size "clamp-on" filter/hood forl the Elmars, Summars and Hektors. But for screw-in versions I think 34 should be about right.
Malcolm M
I based my information on a 1964 edition of Matheson The Leica Way. I presume that, like other lenses such as the 5 cm Summar, it takes either 34 mm screw-in or A36 fall-off.
Off on a complete tangent, I came across this website a while back (looking for a 19 mm UV).
https://www.ebay.com/str/sanmaocamera
It’s the first mention I’d ever seen that the 3.5 cm Summaron takes 22 mm filters, and it’s true! (Also fits Kodak Retina). Now everyone will write in saying that it’s common knowledge.
healyzh
That sounds like a book I should add to my library. I can't seem to find anything in a period copy of "The Leica Manual" (I have several editions).
Actually my 35mm is a f/2.8 Summaron, I've no idea on the filter size, and I'm using a screw in lens-hood from China. Actually taking a quick look, at least the M-Mount 35mm f/2.8 Summeron uses 39mm filters.
Digging deeper the "Leica Pocket Book" 7th Ed., the f/3.5 started as A36, and switched at some point to E39. The f/2.8 is just E39. That's good to know, I'm thinking of picking up a f/3.5 LTM lens, now that I'm using a IIIf a lot.
peterm1
Further flexibility in choice of lens hoods can be had by using a stepping ring.
A trick I use is to mainly use 43mm as my standard for smaller diameter lens -37mm, 39mm, 40mm, 40.5m, 41mm etc. Lens hoods seem to be pretty readily available in a variety of configurations in 43mm diameter and using this as a standard means that one hood (or one hood type) can often serve for multiple lenses with the addition of the appropriate adapter ring. If the Hektor lens does accept a 34mm screw in hood then I have checked and confirmed that a 34mm to 43mm (or other diameter if you prefer) is available.
Including this one which I like very much though it might be a bit overpowering on the Hektor but I include it here mainly for interest. Also it is somewhat more expensive than the standard Chinese offerings which as you know cost no more than a paltry few bucks. This one is around $30.
https://www.ebay.com/itm/43mm-Squar...513394?hash=item2837d6c332:g:lRAAAOSwvjdZRNOu
In any event there are a number of options. This one I like especially and have it in black and alco chrome for use on various WA lenses. it may be more suitable though it has the look of alter hood designs.
https://www.ebay.com/itm/New-metal-...=1622662876647ba01d39e5b44502a8f02070b6fb2f9e
martinjames
Mr_Flibble
Cool. I'm still waiting on mine to arrive.
Mr_Flibble
Mine finally arrived yesterday. Took its sweet time, but that's what you get for ordering from China
It feels solid enough.
While it does fit on the Hektor, it does not screw down all the way, as visible in MartinJames's photos. I suspect the thread pitch isn't quite the same between the hood and the lens.
Not sure if this will cause any vignetting on photos.
Will need to do a couple of tests.
Antoine31
Hood For Hektor 28mm
Can anyone suggest an alternative hood for my 28mm F6.3 Hektor? The originals are few and far between, and after much searching I've only seen one for sale, at an astronomical price. I also bought a cheap hood from China that claims to be useful for the 28mm lens, but it seems way too deep for that focal length. I'm waiting to process the results with that hood, but meanwhile are there any other possibilities?
D
Deleted member 65559
Guest
Antoine, I'd run some film through with the Chinese hood to see if there is any vignetting. If there is, it's easy enough to cleanly grind down the front edge with simple tools. I use a FISON (5cm) on my 35mm Elmar and have no vignetting.
analoged
Share a pic of the Chinese hood? Have you used it? Vignettes?
