Alternatives to ABLON
If I remember correctly, a few years back Ffordes Photographic in Scotland were selling exact replicas of the ABLON. No idea about price, or if they still have any though.
John
Did you see what a wonderful hood this guy has on his Elmar? It seems to have f-stop control too!
Erik.
Erik,
That may be a Cooke and Perkins item. I have the remains of one somewhere, if I can find it I will post a pic. It has aperture control and also comes apart to accept filter glasses.
C&P also made a very good Contax to Leica adaptor. Haven't seen one for years.
Michael
Erik,
Michael
I believe it's actually a custom hood manufactured by a repair shop in korea.
No Ablon needed
No Ablon needed
There is no need at all for an Ablon, although it is fun to own I suppose.
Cock the shutter, put it on 'Zeit' and open the shutter.
Unscrew the lens.
Just cut the slightly rounded end of the film off square, insert it into the clip of the roll as usual, and place the film gently inside, making sure the film roll and take-up roll descend into the camera at the same rate.
Look inside. If necessary, gently use a finger to make sure the film has engaged the leader teeth correctly. If OK, put the lens back on and advance the film as usual. Voila !
I got this from a guy in YouTube and it works for me every time without fail.
Easy and fast also. Has saved me a lot of headaches.
Ciao,
Theo
Tadeyev: sounds complicated... I for my part precut my rolls with a scissor. 20 perforations, slightly rounded at the end.
That's it. No futzing around with open shutters, putting your fingers inside the camera or cards.
I bought one of those "PRINZ" film trimmers on Ebay for $10.00 plus shipping a few years ago. Now, I think the same seller is trying to sell them for as much as $100.00.
I use it by preparing a few rolls before I take the camera out, but have had just as much luck just fiddling the film into the camera without trimming it.
Unscrew the lens.
Ciao,
Theo
Dear Theo,
Good grief! How often do you load your camera?
This works until it doesn't; until a film chip breaks off and lodges in the bowels of the camera.
The only time I use the ABLON device is to cut the V shaped end of a roll to feed into the IXMOO cassette. The leader I just trim with a pair of scissors - being careful not to cut through a sprocket as that tends to jam the advance - or pull off a chip that will keep wandering around in the camera. For large volume IXMOO loading I made a brass plate with a couple of pins to register the film, a V shaped end and a small bar across to hold the film in place. It is much quicker than the rather fiddly ABLON. For LTM cameras I just double the leader lengths - and trim it. At home I use the scissors - in the field a quick "bite" with the teeth and tearing it off seems to work well too.
Dear Theo,
I assume you are implying that it is too much effort?
It might sound like a lot of work, but it only takes less than one minute 😀
That being said, I suppose if you are shooting a lot of film and can prepare in advance with an Ablon, or trimmed leaders, then you might shave it down to half that time.
My only point was that an Ablon (or cutting the leader for that matter) is not an absolute necessity - which is what I always thought until i tried this out.
Cheer,
Theo
Thanks all for the tips, tricks and advice. Many of which I've been trying with varying success.
In the end I've got a Prinz one coming from the USA for significantly cheaper than people seem to be buying them for here in the UK. If it could bring some California sunshine over with it that'd be much appreciated too.
Got my FILCAs, got my trimmer, am good to go 🙂
Do it carefully. The only chips I had, fell away from film I trimmed by hand then with that PRINZ film template.
If I could get my hands on a real ABLON template I'd be much happier. I just can't seem to get my head around paying the $80+ dollars it seems to be going for.
For the bottom loaders I've had, I used small scissors and trimmed a few rolls ahead of time.
What I also did at the beginning was to draw the trim line with a sharpie marker and cut along that. After a bit of practice, I didn't need to draw the line. It helped me quite a bit to get consistent results.
Rob
