Colin Corneau
Colin Corneau
A hundred different respondents will give you a hundred different answers -- none any more or less valid than any other.
They're starting points, at best. Your experience, combined with your unique methods of processing, will give the real answer. (FWIW, it's a tie for me between Rollei Retro 100 and Acros).
What gives me pause is - you mention getting your film "professionally processed"...you're outsourcing it to a lab?
In that case, it won't really make as much of a difference. I really recommend you do this yourself, to truly make the process and the film "your own". That one step alone will affect your results more than any choice of film you make.
Best of luck
Best of luck
