mc_vancouver
This weeks's issue of The New Yorker carries an article by film critic Anthony Lane on the history and attraction of the Leica M series camera which is well worth reading.
http://www.newyorker.com/reporting/2007/09/24/070924fa_fact_lane
Also there is a link to an older article profiling HCB: http://www.newyorker.com/archive/1996/11/04/1996_11_04_042_TNY_CARDS_000376491
Becuase the link may expire by the time you read this posting, I have the pdf file of the Anthony Lane article, but unfortunately pdf is not an allowable extension here.
Go Back
Print this page
Skip to content
Subscribe to The New Yorker
A Critic at Large
Candid Camera
The cult of Leica.
by Anthony Lane September 24, 2007
Text Size:Small TextMedium TextLarge Text Print E-Mail Feeds
Leica advertising from 1935, when the camera was widely in use by Europeans.
KeywordsLeica;Cameras;Photography, Photographers;Barnack, Oscar;Cartier-Bresson, Henri;Rodchenko, Aleksandr;Digital Cameras
Fifty miles north of Frankfurt lies the small German town of Solms. Turn off the main thoroughfare and you find yourself driving down tranquil suburban streets, with detached houses set back from the road, and, on a warm morning in late August, not a soul in sight. Nobody does bourgeois solidity like the Germans: you can imagine coming here for coffee and cakes with your aunt, but that would be the limit of excitement. By the time you reach Oskar-Barnack-Strasse, the town has almost petered out; just before the railway line, however, there is a clutch of industrial buildings, with a red dot on the sign outside. As far as fanfare is concerned, that’s about it. But here is the place to go, if you want to find the most beautiful mechanical objects in the world.
Many people would disagree. Bugatti fans, for instance, would direct your attention to the Type 57 Atlantic, the only car I know that appears to have been designed by masseuses. Personally, I would consider it a privilege to die at the wheel of a Lamborghini Miura—not difficult, when you’re nudging a hundred and seventy m.p.h. and waving at passersby. But automobiles need gas, whereas the truest mechanisms run on nothing but themselves. What is required is a machine constructed with such skill that it renders every user—from the pro to the banana-fingered fumbler—more skillful as a result. We need it to refine and lubricate, rather than block or coarsen, our means of engagement with the world: we want to look not just at it, however admiringly, but through it. In that case, we need a Leica.
There have been Leica cameras since 1925, when the Leica I was introduced at a trade fair in Leipzig. From then on, as the camera has evolved over eight decades, generations of users have turned to it in their hour of need, or their millisecond of inspiration. Aleksandr Rodchenko, André Kertész, Walker Evans, Henri Cartier-Bresson, Robert Capa, Robert Frank, William Klein, Garry Winogrand, Lee Friedlander, and Sebastião Salgado: these are some of the major-league names that are associated with the Leica brand—or, in the case of Cartier-Bresson, stuck to it with everlasting glue.
Even if you don’t follow photography, your mind’s eye will still be full of Leica photographs. The famous head shot of Che Guevara, reproduced on millions of rebellious T-shirts and student walls: that was taken on a Leica with a portrait lens—a short telephoto of 90 mm.—by Alberto Díaz Gutiérrez, better known as Korda, in 1960. How about the pearl-gray smile-cum-kiss reflected in the wing mirror of a car, taken by Elliott Erwitt in 1955? Leica again, as is the even more celebrated smooch caught in Times Square on V-J Day, 1945—a sailor craned over a nurse, bending her backward, her hand raised against his chest in polite half-protestation. The man behind the camera was Alfred Eisenstaedt, of Life magazine, who recalled:
I was running ahead of him with my Leica, looking back over my shoulder. But none of the pictures that were possible pleased me. Then suddenly, in a flash, I saw something white being grabbed. I turned around and clicked.
He took four pictures, and that was that. “It was done within a few seconds,” he said. All you need to know about the Leica is present in those seconds. The photographer was on the run, so whatever he was carrying had to be light and trim enough not to be a drag. He swivelled and fired in one motion, like the Sundance Kid. And everything happened as quickly for him as it did for the startled nurse, with all the components—the angles, the surrounding throng, the shining white of her dress and the kisser’s cap—falling into position. Times Square was the arena of uncontrolled joy; the job of the artist was to bring it under control, and the task of his camera was to bring life—or, at least, an improved version of it, graced with order and impact—to the readers of Life.
Still, why should one lump of metal and glass be better at fulfilling that duty than any other? Would Eisenstaedt really have been worse off, or failed to hit the target, with another sort of camera? These days, Leica makes digital compacts and a beefy S.L.R., or single-lens reflex, called the R9, but for more than fifty years the pride of the company has been the M series of 35-mm. range-finder cameras—durable, companionable, costly, and basically unchanging, like a spouse. There are three current models, one of which, the MP, will set you back a throat-drying four thousand dollars or so; having stood outside dustless factory rooms, in Solms, and watched women in white coats and protective hairnets carefully applying black paint, with a slender brush, to the rim of every lens, I can tell you exactly where your money goes. Mind you, for four grand you don’t even get a lens—just the MP body. It sits there like a gum without a tooth until you add a lens, the cheapest being available for just under a thousand dollars. (Five and a half thousand will buy you a 50-mm. f/1, the widest lens on the market; for anybody wanting to shoot pictures by candlelight, there’s your answer.) If you simply want to take a nice photograph of your children, though, what’s wrong with a Canon PowerShot? Yours online for just over two hundred bucks, the PowerShot SD1000 will also zoom, focus for you, set the exposure for you, and advance the frame automatically for you, none of which the MP, like some sniffing aristocrat, will deign to do. To make the contest even starker, the SD1000 is a digital camera, fizzing with megapixels, whereas the Leica still stores images on that frail, combustible material known as film. Short of telling the kids to hold still while you copy them onto parchment, how much further out of touch could you be?
To non-photographers, Leica, more than any other manufacturer, is a legend with a hint of scam: suckers paying through the nose for a name, in a doomed attempt to crank up the credibility of a picture they were going to take anyway, just as weekend golfers splash out on a Callaway Big Bertha in a bid to convince themselves that, with a little more whippiness in their shaft, they will swell into Tiger Woods. To unrepentant aesthetes, on the other hand, there is something demeaning in the idea of Leica. Talent will out, they say, whatever the tools that lie to hand, and in a sense they are right: Woods would destroy us with a single rusty five-iron found at the back of a garage, and Cartier-Bresson could have picked up a Box Brownie and done more with a roll of film—summoning his usual miracles of poise and surprise—than the rest of us would manage with a lifetime of Leicas. Yet the man himself was quite clear on the matter:
I have never abandoned the Leica, anything different that I have tried has always brought me back to it. I am not saying this is the case for others. But as far as I am concerned it is the camera. It literally constitutes the optical extension of my eye.
Asked how he thought of the Leica, Cartier-Bresson said that it felt like “a big warm kiss, like a shot from a revolver, and like the psychoanalyst’s couch.” At this point, five thousand dollars begins to look like a bargain.
...the article continues...
Go Back
Print this page
Skip to content
A Critic at Large
Candid Camera
The cult of Leica.
