Spyderman
Any experience? Is the material the same as the original? Especially - are the straps the same width?
Thanx in advance.
Thanx in advance.
fidget said:You are especially brave to replace just the material in your curtains. I wimped out and bought a nice set (several actually) from a Ukraine seller, Blyatnikov.
Dave...
Spyderman said:Any experience? Is the material the same as the original? Especially - are the straps the same width?
Thanx in advance.
Spyderman said:Jay: what material do YOU use for the curtains? I'm just curious...
Xmas said:Jay
So if I visit the islands you are the person walking around with a FSU camera and a rain coat with large holes?
Noel
Spyderman said:Hi,
just measured the 2 original materials. The original FSU strap is 0.15mm thick and 4mm wide and the curtian rubberized cloth is 0.3-0.35mm thick.
In a PM from Jay he mentioned that the strap and curtain should be the same thickness... how come the Russians used different thickness ?
