Sid836
I have recently acquired an Olympus 35RC. Everything works perfect on it except that when setting the aperture ring at off the shutter does fire at maximum aperture. Also, at A even without battery in it it does fire at maximum aperture. I thought that the ring was loose, but when I turn it to flashmatic, it works as expected.
I will be using it in manual anyway, but what could be wrong with that? What makes it not locking the shutter under insufficiency light or when set to off?
Also, fiddling with the battery compartment the piece of metal that connects to the - of the battery came off. I had my chances to test the camera, but now... What can I use to put it back in place?
