Are Nikon RFs for collectors and Leica Ms for users?
I think there's a lot to be said for the fact that the difference in ergonomics between the Nikons and the Leica Ms (which is what I assume we're talking about here) is significant, and being used to one system can color one's impression of the other.
But I do think that if someone with no experience with rangefinders were handed an example of each, the Leica would be preferred. Why? Multiple framelines and a really crisp RF patch. Also, no infinity lock -- a "feature" I confess I don't understand. I don't see the focusing wheel as a plus point for the Nikons; after all, to the extent it's usable, it's really not usable at all with lenses that require the outer bayonet (i.e., everything but 50s).
Roger, the going rate for a user Nikon S2 with 50/2 is around £350. Hardly expensive for anyone used to Leica prices.
Fair enough. But still more than I as a user am willing to pay for a camera with a limited choice of lenses which were for the most part, at their best, roughly comparable with their Leica equivalents of 50 or more years ago.
What's left to discuss? You made it clear that you prefer Leicas, and now you know that some disagree that Nikon RFs are "inferior" & some agree.
No I am a user, a Leica user. I have Voigtlander R2c, Contax IIIa and Canon RF. No Nikon RF. But I have Nikon F which is derived from Nikon RF. The Nikon F's layout is inferior to Leica M too. The shutter release is near the back not very user friendly. The base concept of Nikon RF is similar to Contax except shutter is borrowed from Leica. I did try a Nikon SP in store and the rangefinder is kind inferior to Leica M. For these Nikon RF die-hard fans please hold your emotion, I just want to have a constructive discussion.
It works very well with wide angle lenses, assuming they a have not be gummed up by a repairman with a lot of grease.
Well, the grease was OK when it was fresh...
This is the fundamental problem, isn't it? That many people compare ill-maintained, jammed-up 50-year-old cameras with newer cameras or with better designs that don't require servicing every few years.
The results count. A set of an S2 with a Nikkor from 1957 impresses even today.
Nikon S2, Nikkor 50mm f/1.4, Tmax400.
Erik.
Nice image
There is more, should you oil your Nikon/Contax RF focus helical or not? From Contax repairman, you should leave it dry. However, from the video of Nikon SP 2005 design team they do lubricate the helical thread. Which one is better?
>>This is the fundamental problem, isn't it? That many people compare ill-maintained, jammed-up 50-year-old cameras with newer cameras or with better designs that don't require servicing every few years. <<
With limited excpetions, the Nikons seldom need servicing. Often, more harm than good can be done by an inexperienced repair person who greases something that was never intended to have any grease, just needed a quick cleaning.
Ah, so maybe the subject line needs to be changed to something about cleaning/lubricating the focus helical. 😉
IIRC from speaking to the late Pete Smith, he said that dry works & was the standard practice back in the day, but I don't see why dry graphite like that used in the video wouldn't also work to make it even smoother (& who am I to argue w/the Nikon techs?).
Any good photographer should be able to take good photos with whatever camera and lenses, provided that the camera shutter and finder both work well and the lenses aren't dogs.
When it comes to ergonomics it's a question of personal preference only, then any sensible person can get used to some gear with ergonomics found questionable at first handling.
The late famous (and remarkable artist) Jean-Loup Sieff used some Nikon F gear as well as his Leica M gear and even himself couldn't remember which of his masterpiece photos had been taken with which system brand.
For personal reasons I personally prefer my Nikon RF cameras over the Leica M cameras I used to own (and re-sold some years ago) but if I was given a Leica M I would use it again with no problem, and fool would be someone who would find any difference of style from the photos I use to take with my Nikon RF stuff.
Those "this is better than that" discussions cannot be constructive - they all relie upon personal feelings.
If somebody could demonstrate why a film camera having a focal plane shutter from 1s to 1/1000 and supporting interchangeable lenses having some excellent resolving power is "superior" to a film camera having a focal plane shutter from 1s to 1/1000 and supporting lenses having some excellent resolving power, I'd be happy to accept the demonstration results.
But - nobody dit it so far. And nobody will, ever.
I don't know about the first two statements on this list. My experience suggests otherwise.
I can load a CL faster then my m6. The back on CL is similar to the Nikon RF. the trick w/ the CL was use the neck strap to hang both sides of the camera around your neck while u are replacing film. I have used this trick before while running to catch to my wife after taking a shot a Zion...
The Nikon rf does not have the same setup in terms of the neck strap, but one can still put the back in your pocket while changing. So not quite as ast as the CL, but could still be faster then the my m6, since the bottom needs to be put in your pocket as well and there is only a small flip up film winder to make minor adjustments to film leader positioning.
But at end of they day, if u are really good at film changing, I don't think anyone style will beat the other.
Gary
(VinceC) Nikon sold a BUNCH more cameras ... Nikon Fs ... and quickly left the RF market due to the overwhelming success of its SLR.
(VinceC) The S-mount was inferior to the M-mount. No question. Rather than reinvent it, Nikon moved on to dominate professional and premium amateur market
(DominikDUK) . . . Nikon RF cameras were not really available outside Japan and Asia and in some European countries they were not available until the late 1960's. Furthermore many Americans would not buy goods made in Japan. Besides the Nikon F outsold I believe the Leica cameras by quiet a margin so no reason to build RF cameras anymore. . . .
I have to agree with you that the prices are outrageous and often make them collectors items
None of the above untrue. But they still argue that the M-series survived because no-one has ever made better RF cameras.
Roger . Interestingly the Ms don't excel in any single thing the Contax has the more precise rangefinder and focus, most interlensshutter RF are quieter, the Konica's have better parallax correction and the list goes on. Were the Leica excels is compromise it incorporates everything a photographer needs the other cameras might beat it on a single thing but the Leica wins in the overall package. For me the best RF would be Contax with Konica Bright line Viewfinder with frames for more than one focal length.
The Nikon RFs are still superb cameras though
Kenj,
Did u expect anything else with a thread title like that 😀 personally I can c them both collectible.. Or both users.
I c as many m in prestige condition as beat up users. Personally, I would rather have the beat up user.. Nikon or Leica :angel:
On the Nikon rf, never really liked the knurled focus knob for the 50, always ended up using the lens itself to focus.
Now a days I rarely shoot 35mm film..
Gary
. . . Were the Leica excels is compromise it incorporates everything a photographer needs the other cameras might beat it on a single thing but the Leica wins in the overall package. . . .
Almost certainly true. Plus, of course, the Leica M is simpler and cheaper to build than a Contax or Contax derivative.
If I recall correctly, the Associated Press issued a Nikon F plus a Leica M2 to each Vietnam correspondent, thus setting the tone for peaceful co-existance.
At the risk of introducing politics into the thread, I don't seem to recall peaceful co-existence working very well in Vietnam.
I thought that the "dream outfit" in that era was 2x M (wide and standard) + F (long).
