Battery Adapter for Konica T3
sooner
2:04 AM
Oklahoma
Hi All, I know this has come up before but I bought a MR-9 battery adapter thinking it would reduce the voltage from 1.5 to 1.35 volts, but then I realized it's too big and won't fit inside my Konica T3! Guess you truly can't believe everything you read on the Internet. Does anyone have a suggestion? Does the MR-44 adapter work for this model camera? Has anyone come up with a better solution recently? Thanks in advance.
Put a 386 battery in the adapter if your problem is too thick. The 386 is same voltage in a slightly thinner package than the LR/SR44 battery.
Thanks, it looks like I need the H-C MR-44 adapter, only available from Kanto in Japan. The MR-9 was too thick/wide for the T3. I'll go ahead and order it from them. Appreciate the help!
Ah well if the adapter is too wide of diameter, that's the more difficult problem. I've had the thickness problem in a few cameras and a meter, but diameter was fine. The 386 solved it so elegantly.
Good luck with the new adapter.
