Bessa R2 + Unomat B24
werf
andrey ivanov
9:28 AM
moscow, russia
Can i use bessa-r2 and unomat b24?
Unomat is
high voltage flash, and recommended don't use with digital canon and nikon.
[sorry my russian-english]
I guess the flash sync circuit should be independent fro the metering... and metering is the only electronics inside the camera... But it might be dangerous to you! Bessa R2 has a PC sync on the left end near the rewind crank and if the PC sync and hot shoe are on the same circuit (just guessing) you might get an electric shock!
