Sykomor
I think the Ultron 35/1.7 ltm could be found for around $350. Add the ltm to M adapter.
I stand corrected on the price difference, Ko.Fe. Thanks for the clarification. it would seem that the price of a Summaron-M has almost doubled since I was considering buying another one just a couple of years ago. Astonishing!For ebay price of new Nokton 40 or new Skopar 35, you could only get used 35 3.5 Summaron. Even if purchased locally. At least where I purchased it locally once.
Summaron 35 2.8 is much more expensive lens now...
I was never overwhelmed not with Skopar nor with f3.5 Summaron...
This might be worth waiting for.
https://www.35mmc.com/18/11/2017/7artisans-35mm-f2-pre-pro-sample-photos/
Michael
Depends; what is your budget?
Lenses that I can recommend to you based on my own use of such lenses:
Zeiss Biogon 35/2 (modern look, flare resistant, brilliant colors)
Canon 35/2 ltm (still modern look; sharp; cheap)
Summicron 35/2 Version 1 (a classic; high resolution)
Canon 35/1.5 ltm (rare; performs very well)
Nikon 35/1.8 (special look to images from it; overpriced in ltm; small)
I do not own any CV 35mm lens, but I read about positive feedback on such lenses.
For a modern look, the Voitlander Color-Skopar 2.5/35 closely followed (in budget rankings) by the Zeiss 2.8/35 C-Biogon.
In comparison to the 35mm Summaron (which is as near-as-damn-it rectilinear) the 35mm Nokton has very pronounced barrel distortion. The 40mm Nokton, OTOH, isn't nearly as badly affected in this way as is the 35mm. but is still not as good as the Summaron.
The edge fall-off in terms of sharpness follows the same pattern as above with the Summaron being comfortably ahead of the 40 Nokton with the 35 Nokton trailing both..
Quite the contrary, nick. I have a great respect for Voigtlander's lenses and in fact the 35mm Nokton seems to be the odd one out in that it seems to be the least corrected of the range - which is a very great pity as I did want to get one.Ah OK, I misread and thought you meant all Voigts. The 35mm Ultron (similar price new to a used Summaron) should be a much closer contest.
Really like the IQ on these samples... I think I’ve made up my mind on this one! My M6 still has to get here, plus I plan on getting it CLA’d anyway so waiting for a Feb release makes a lot of sense for me.
Thank you all for your input! Hopefully this thread will also help other new rangefinder newbies like me in the future 🙂
It cost me a little extra but I looked for and found a great deal on a used Zeiss Biogon ZM 35/2. There are times when I wish I had gotten f1.4 in something, but very rarely. I particularly like the colors and lack of distortion from this lens.
Hey all! I just picked up an M6 for a pretty good price (first M rangefinder for me!), and am currently looking to pair it with a 35mm lens. Been doing a bunch of research on different lenses, from the Zeiss Biogons to Summarons, but it seems like a lot of the secondhand prices have gone up since the original post dates of those lenses. That said, what do you guys think would be the best bang for buck 35mm nowadays? Appreciate any thoughts!
