Robert Lai
I can only speak of the cameras with which I have experience. In 35mm SLRs, these are Nikons and Canons. In medium format, I prefer the Rolleiflex or Autocord TLRs.
With respect to Canon, I had the FX, which was the first to introduce the FL lens mount. This later evolved into the FD mount.
The FX had weaknesses. Primarily, it used a spring clutch to couple the wind lever to the winding shaft. If there was a problem with the clutch, then the shutter would jam. By the time the FTb came around, Canon had fixed all of these issues.
Also, the FX's meter scales were shifted by a silken cord. With time, it is a certainty that the cord will break, and your meter will not function. The semi-spot metering in the Ftb is one of the best implemented TTL metering schemes in 35mm SLRdom.
The QL feature of the FTb also works great. It is the easiest 35mm camera to load.
The early FL lenses, such as the 58mm f/1.2 had only a single guide pin, so the focusing could be a bit rough. They corrected this on subsequent lenses. Worse, with hot weather the grease from the focusing helical could migrate into and gum up the aperture mechanism, leading to overexposure.
With issues like this, I can understand why Mr. Market went with the Nikon F as the professional SLR.
Of the Nikons, I do feel that the F3 is the best handling of them all. However, the original question was regarding the best mechanical SLR cameras. I still stand with the Nikon F and F2.
