SimonSawSunlight
Simon Fabel
If you try a Yashicamat 124 (NOT the 124G), you won't find the plastic you disliked in the 124G.
The meter is less likely to work though, the big improvement on the 124G's was better meter connections, but (in the later ones especially) the construction wasn't as good on the body. (Lenses are the same though.)
Aside from that, there's not much w/ a meter out there in that budget. I'll go along w/ some of the other guys, and say a rolleicord or a tessar-lensed rolleiflex and a handheld meter. (or even the mamiya TLRs)
-Brian
+1.
and the meter in mine does work 😀
