N
NoTx
Guest
I have heard that the Leica M .58 viewfinder works as a a viewfinder for the 25mm.. using the whole thing. Is this accurate?
NoTx said:I have heard that the Leica M .58 viewfinder works as a a viewfinder for the 25mm.. using the whole thing. Is this accurate?
xayraa33 said:if you have a 35mm lens get a 25mm, as the 28mm is too close to a 35mm lens.
visiondr said:Well, fellas, I pulled the trigger. A brand new Zeiss Biogon ZM 25mm/2.8 is on its happy little way to me now. I'll try using it without an external finder for now.
I'm all wet with anticipation! 😉 😱
Gary B said:I would suggest going with the widest lens that your camera shows in the view finder unless you do not mind using an aux. viewfinder. M8 is 24 mm, M2 is 35, others Leicas can be found on the Leica site or other places on the web.
GaryB
Randyvrgard said:Just out of curiosity, GaryB, and not to challenge your statement above, but what lens is that on the CL in your avatar picture?
Thanks,
Randy
