richardHaw
junk scavenger
one more note about sanding. some parts are already thin and sanding it will make it thinner. be careful, you don't want to go this route 😱😱😱
Can't seem to find a black paint SP anywhere in UK, so thinking of painting a chrome one, I've repainted leicas in the past and have boxes of Nikon F black paint parts for any of the dials etc. Has anyone repainted one?
I read somewhere the back has quite thick chrome that is hard to remove?
Thanks Fraser.
One other thing I found interesting concerned the black paint back I obtained relative to the original SP body I was starting with. Am fairly certain at this point that the N.O.S. black paint back I had was from a 2005 SP, and not an original SP. Why? The paint on the back was both a different color black than the black paint (there is some on the frame) on my original chrome body, and was of much higher quality. The black paint on the original was thicker, and glossier, than the paint on what I am now sure was from the re-issue. Also, the paint on the re-issue is perfect, and the paint job Nikon did on the bodies originally had a lot of orange peel, relatively speaking, though you might not notice it unless you were faced with sticking the new back on an original frame, as I was.
Regarding the frames counter cover, something to note if doing all this is that the counter cover on an original SP is different from the counter cover they used on the SP 2005 (though the fit is interchangeable). For whatever reason, when Nikon did the SP re-creation, they used the style of cover from the F, not the SP.
Grays Of Westminster have a 'NEW' Black Paint SP in stock, but get your wallet ready . . . just a mere £5000 🙁
Interesting reading, Larry!
Your BP back is a bit of a mystery as I'm sure its not a 2002/2005 reissue S3/P back. You can easily confirm that by the ASA dial on the base with red and white indicator arrows. The reissue backs have an ISO dial and only one white indicator arrow. The metal of your back also feels thicker than metal used on the reissue backs. Maybe its a back from an S3 Olympic?!
There's minor differences between earlier and later SPs during the original production run, and the frame counter is one of them. The six concentric circles frame counter cover was used on later SPs during the original production run from about the time the Nikon F was released.
It's not only the rivets, it's the leather on the back. There isn't a close aftermarket match to the leather, and stripping the chrome and nickel is extremely difficult to do properly without having the chemicals touch the leather.
I would'nt do it.
Leicashop will have em too
http://www.leicashop.com/vintage_de/nikon/35mm-viewfinder-cameras.html
The "leather" on the back of the S2/SP/S3/S4 isn't leather, it's vinyle, which is quite thick and strong so that it can be easily removed without any damage and glued back once the paint job is done.
On the Nikon M and S it's some thin genuine leather, which would be very difficult to remove without destroying it indeed.
Thanks to Larry for all the information provided here about how his black SP job went on.
