Bluefire Police film with Developer
The negs look underexposed. The film is probably around 25 ISO in practice.
On a normal density neg you'll find the dust/spots are much less of a problem.
I would imagine it is very similar or might even be Agfa Copex which is a document type film which needs to be shot at less than 20EI and also needs low contrast developer for pictorial results.
Every so often a company packages these types of film (AKA Lippmann emulsions) and LC developers, I think the Blufire one is a Copex type with a developer designed to get maximum speed from the emulsion while still give printable contrast.
I tested one called Gigabit (basically Agfa Copex and Spur developer)
http://photo-utopia.blogspot.co.uk/2007/03/gigabit-film-gigabit-film-is-slow.html
You can buy Copex and develop in dilute Rodinal all these films really should be shot at EI 6–25 for pictorial results.
The film looks a little different from conventional emulsions, even at EI 20 they look as if they need a little more shadow detail, I'm guessing they should be shot at lower EI
They seem to print/scan well though and are useful for certain types of shot.
Mark Antony
Well the spent developer was likely much of the problem. I ran my first roll at ISO 80 as per the data sheet, my usual practice. I shot a lot of ATP a few years back, never really ended up getting along with that because it was so contrasty despite lots of adjustments in exposure & development. This Bluefire has been around a long time, thought I'd give it a go. I'll likely shoot this next roll at 80 and 40 side by side to see what I get, but I don;t see myself continuing with it for long. 🙄
I believe it is Agfa Copex as well. Edge printing is '05 71' and 'PAN'
These do seem designed for scanning with densities like that. I don't scan film so not a good fit for me most likely. I do enjoy playing tho.
Yes they scan well, but surprisingly they print OK on grade 2 paper also. The emulsion is pretty high in contrast (even with special developers) at suggested speed and low in latitude–pretty much a given for a thinly coated monodisperse emulsion.
The negs I posted were at the suggested ISO40 and dev times, halving the EI to around 20 really helped.
hi, when i placed the order for this bluefire police, there was reference to Adox Canada.
http://www.adox.net/Products.htm
Maybe Adox CMS ? according to this website:
http://www.adox.de/english/ADOX_Films/ADOX_Films/ADOX_CMS_Films.html
if used with Adotech, iso goes up to 80, film base is also transparent.
however, according to david foy who is involved in Bluefire, i quote this:
""Bluefire Police" is Tura Pan Line, a panchromatic EI 100 microfilm, packaged in 24-exposure 35mm cassettes. Tura does not sell it in retail quantities."
raytoei
another link,
"Quote from: David Foy
The film is Agfa microfilm, spooled for me by Tura when they were still in business, and edge-marked by them as "Pan Line." The next batch will be spooled here and edge-marked "Bluefire Police."
It is well suited to pictorial photography when paired with a suitable developer.
It is not sold as Adox, but as Bluefire Police. You are correct that it is bad business to confuse customers."
http://nelsonfoto.com/SMF/index.php?topic=3937.0;wap2
Frugal Photographer hasn't had developer for a while now, so I got 3 rolls and will develop in HC-110G. Well, really 1:125, I have researched a time, temp and agitation for this developer and will give it a try. I'll post as soon as have results.
my reference wouldn't be useful to you as
I stand developed it in tropical temperature
of 30c 🙂
40 Mins Rodinal Stand with mid-point agitation
at 30C
M6ttl with 50 Cron
attaching 2 images, scanned and scanned + adjustment.
raytoei
I shot my first roll of Bluefire Police. I used 40 on half and 20 on the second half of the roll. My development was with HC-110 1:125 for 25 minutes, 30 seconds initial agitation, and then ONE inversion every five minutes (so four during the remaining minutes after initial agitation) 68 degrees. I got most of this from Donald Qualls on the net, but I modified a little. The negatives on the 20 EI look very good and I will post after I scan tomorrow. Just from looking at them I would say I will use 10-12 EI next roll and reduce the time to 20 minutes (and I may modify my agitation too, but I'll have to think on that for a while), but scanning is a different ball game with this clear base so we will see.
EDIT: Here are a couple at 20 EI:
As you can see so far that outdoor shots are more contrasty.
nice photos. especially the first one. i am surprised by the 3rd pic as it looks like a picture with an old emulsion. is it grainless as well in hc110 ?
