Bought my first screw mount leica
ozarktax
6:35 AM
uk
Hello
Long time lurker, finally created an account to post.
So I bought this camera sold as a Leica 1, however with the addition of a rangefinder, I believe it may have gone back to the factory for modification.
What I didnt notice when purchasing was the missing screw on the elmar and the lens appears to be a bit cross-threaded, oops. Ive probably overpaid at £260 given the work it might need, but
I was drawn to the heavy brassing and wondered where the camera has been and what it has seen.
I was wondering if anyone knows any more about this camera and particularly what modifications its likely had.
The serial is 210446, which puts it at 1936 i believe.
It appears to be a straightforward Leica Standard -> Leica II conversion, and in good condition for it's age.
You'll spend more than £260 to have it restored to working condition (if that's your intent), but it looks like a decent buy to me. Fortunately, the cross-threaded part appears to be the lens helicoid, not the camera body. Lens can maybe be salvaged, but if not, it has value as a parts unit. Am guessing lens was frozen on camera body, and someone attempted to remove it by brute force, shearing off the infinity stop. Worst-case scenario is that the lens's mounting flange may need to be cut from the camera body, but most of your value is in that camera body, not the lens.
Thank you all for your replies, really really helpful.
I've emailed Leica to see if they can dig out any information for me, I will try and see when it turns up if the lens helicoid is damaged or the camera body, if it's the camera body I will probably send it back. More inclined to try and get a new Elmar than find a spare lens bayonet.
I agree with Dralowid. The lens's base appears to thread into the mount just fine. This doesn't look like a camera problem.
It looks like the lens's helical threads are not lined up well enough to go together. If it's not been forced/damaged then there's a decent chance that it could be assembled properly. It might require experimentation to determine where to start the threads so that the lens is positioned properly. Some helicals are harder to line up and start than others.
Having written my post it occurred to me that the first thing to do would be to get the lens's mount off the camera, then after that, getting the helical back together correctly is done by trail and error.
I think the body is pretty cool for what it is. Additionally, I don’t think all is quite lost — if you happen to have a set of those hard rubber lens ‘vacuum pad’ sets, you may be able to get the lens’s mount off, with maybe a tiny bit of Liquid Wrench. And I don’t think that fixing the lens is going to be a big deal. If that screw on the back of the infinity lock button is missing (as well as the spring), they’re easily found on eBay (either originals or repros from China). You might actually have a bit of an easier time threading the lens back into the mount if the lens barrel was extended and locked (it is an extensible lens). Have you corresponded with the seller about paying for a possible repair?
BTW you didn’t mention if the camera is working — is it?
Yes the brassing of camera and knobs is odd and unusually consistent as if it has been subject to some 'intervention' The wear around the lens also makes one raise an eyebrow also
Having said that, the overall effect isn't too bad, if it works!
The last thing I want is a camera that has been brassed intentionally, that removes the allure behind the history for me (stolen valour 🤣)
The camera fires, the slowest speeds stick , but the camera feels quite nice to operate. It probably needs a new beamsplitter as the patch is almost impossible to see.
The camera came from an auction that is usually associated with house clearances etc so If it were intentionally brassed I imagine it was done years and years ago.
