jepp
The pourcentage of a battery is calculated on a theoretical capacity. A new battery fully charge or an old one fully charge will show you the same 100% but the real capacity is differente.
Your 10 pourcent difference could in fact represente a very small difference as the czlculation is done each time you mesure it.
So I suppose, when auto off is activated,you don't drain your battery, but when you check you can have slight difference.
( I am not very clear...sorry)
