Wow - thanks everyone for the good wishes! I'm considering painting the corner around the Lab 1200 but I've looked carefully at the amount of white light that does leak from the enlarger and I can easily control it with some black card taped to two small sections on the side of the enlarger. If I do that it will save me the paint and the overall white scheme helps keep the place bright with the safelights on. With the plywood sink I started with a full sheet of plywood (8 feet by 4 feet or 2400mm x 1200mm) and gave it two coats of epoxy on both sides before I cut out the pieces. After making the joins (rebate, wood glue and nails) I mixed filler with epoxy to make an epoxy mix with the consistency of putty, then applied fillets that strengthen the joints and make them fully waterproof. After that I applied several more coats of epoxy. Not pretty up close, but very effective - the plywood is fully encapsulated in epoxy so in theory the moisture content in the ply will never change so it should be dimensionally stable. This, and finishing/painting the walls, was the most time-consuming part of the whole job.
Cheers!
