rxmd
May contain traces of nut
I'm currently building a tray stack (I found it's the only practicable solution for a darkroom since we moved to Berlin; as long as my PhD isn't finished I'll have to continue on a student budget). So I'm very much in the same boat, my darkroom is in my "office" and that's a wedge-shaped room of 400 x 130 x 180 cm that my chemistry has to share with about twenty meters of bookshelves, two desks, and a computer with two large CRT displays. Maybe I'll send a picture around once I get it finished.BJ Bignell said:I think I will start with the stacking tray idea for the wet side, and build a rolling shelf/table that fits under the wet side, as shown in the diagram. Any recommendations for the amount of vertical space between each tray? I would guess that six inches (15cm) should be plenty?
A friend of mine had this brilliant idea for a tray stack that I'll copy. I'm starting off with a storage rack from IKEA that looks like this:
They can be bought without basket drawers, too, and the overall height is about 70 cm. I take some drawer mounts that can be pulled out, and fix them to the sides of where the original basket drawers go. Then I build some simple drawers from thin wooden boards, with a bevel around the edge so that if I spill some chemistry it doesn't spill over the edge too much. After that, I can place development trays on these new drawers and work top to bottom, pulling out drawers and putting the paper from tray to tray.
My friend did a spaced out version with a little motor that rocks the whole rack once per thirty seconds or so for agitation, and with little LEDs and timers attached to the side of each tray for proper development times. But that's already the extended version, I guess 🙂
Leaving paper in water for extended amounts of time should be no problem, I used to do that in my other apartment; the only problem couls be that if RC paper floats vertically the corners tend to get bumpy. Putting some soda or hypo clearing agent in the water is a brilliant idea that I've got to try out 🙂
Philipp
