2maneekameras
home on the rangefinder
- Local time
- 6:58 PM
- Joined
- Jan 15, 2005
- Messages
- 145
After, a few years of contemplation, I am embarking on the task of building a home fabricated rangefinder digital camera. I am looking for a bottom load Leica copy to use as the external housing. I bought a Zorki c parts camera with this in mind, but it is too incomplete for my plans. It seems to be just the right size for what I have in mind. I want one that is complete visually from the out side with all the rangefinder objectives, knobs and shutter dials. The shutter doesn't need to work, but it would be a bonus if it did. I also need the bottom plate. I have the ccd and lenses that I need already. I plan to retrofit a stobe into an old flash gun( hopefully with the flashtube inside an actual flashbulb)so I want a camera with a flash pc connector on the body. The camera will be manually focused, with manual apperture settings as well. No lcd screen either, so the process will be similar to using a manual film camera. Suspense until uploading the images. I will post the progress of this project on the rff if I can come up with a donor body. A zorki c or 2c looking for a new home and mission would be preferred. A fed 2 would also be a possibility. Thanks!
