J
jmonat7
Guest
The M9 is still a great camera if you can deal with the limitations but I personally think it is overpriced in the current market. The colors are good, not great, there is also definitely a punch to the M9 photos but it's not anything that can't be achieved in post nowadays.
1. The first 2 batches of sensor replacements are still prone to corrosion because Leica just replaced the corroded sensors with a new version of the same sensor which are still prone to corrosion. Anything from 2015 and onwards are the new corrosion free sensors and are designated CCD ID 15 for 2015 and CCD ID 16 for 2016.
2. Yes. The rendition of the M9 is due to the CCD sensor and color science from Kodak, not the sensor glass corrosion. The replaced sensors render the exact same as the original sensors.
3. Don't buy an original sensor M9. It is just not worth it. Most M9's on the used market have replaced sensors and are only marginally more than an original sensor. If someone is selling an original sensor M9, know that it either has corrosion or will develop corrosion. It is not a random event, it will occur due to the way they designed the original sensors.
4. If you want an M9 but want more malleable files, better battery life, higher LCD resolution, but don't want to double the cost to get an M10, get an M262. I don't know why they are overlooked so often. The M262 is basically the updated version of an M9 in terms of simplicity and function. The M10 is great but the M262 is also great and is much cheaper.
