C41 Photoflo
useless generation
2:03 AM
Adelaide, Australia
Will re rinsing color C41 film with distilled water and a few drops of photoflo affect the film after rinsing in stabilizer? I just developed my first roll and there is quite a few drying marks. I've read online and people seem to have mixed opinions. Any C41 at home nerds want to share their technique?
I do my own E6 and C41, and have added photoflo at 1:300 (or whatever the correct dilution is) to the stabiliser bath solution. Great photos so far, without drying marks. The only problem is that it gets frothy when I try to pour the stabiliser back into its bottle.
Photoflo is a surfactant (wetting agent) it help preventing drying streaks but... it has to be diluted as recommended by the spec sheet. Too much creates problems, too little is ineffective.
Nothing should be touching the film after the stabilizer, or you might be risking long-term permanence of your negatives. I've personally always had bad luck in rinsing C-41 negatives with Photo-Flo. If you have any drying marks, just dampen the corner of a soft sponge with stabilizer and wipe gently.
I use the Tetenal/Jobo kit, which comes with the stabilizer in powdered form. I was getting drying marks even though I had used distilled water. I realized that the marks were re-crystalized stabilizer. I bought a bottle of Kodak stabilizer which I use instead of the powder. This has something equivalent to a wetting agent, and I have had no more problems.
The negs that had marks only had them on the film base side. I also only had a problem with 35mm, 120 was fine. I cleaned the marks up with film cleaner, and they came off very easily.
I ended up rewashing with photoflo and it helped!
With the developer temp is it better to go a little hotter than colder? I kept it in a water bath but the temp dropped slightly during development! How much difference does it really make? How strict should it be?
