Cable release for Leica IIIa
2:04 PM
Lion City, Singapore
Hi all, I was searching the net for a cable release for Leica IIIa, but I am not sure what is compatible.
Some say that its the AR-2 cable Nikon cable release that is compatible with the Leica III. But when I called up one of the local shops here in my country, he said it isn't. So I'm a little confused now.
Need help to verify what to get for my Leica IIIa.
Thanks!
Yes, all 'collar' style mounts since about WW2 are compatible.
And you can buy adapters (little collars or drums with a conventional socket in the top). Kaiser may still make them.
I am also searching for a cable release, only for a If. These ebay links posted here have already expired, so I am afraid I must bother you all with the same questions again, (;
Does a cable like this one -- a Nikon AR-2 -- fit the If shutter by itself or does it require an adapter? If an adapter is necessary, will this one be the proper (for the AR-2 cable w/ the If)?
Thanks!
It's likely that the AR-2 will work. It, or the adapter, is screwed on in place of the shutter button surround. The adapter will take an ordinary ("standard") cable release. That is, you do not need both the AR-1 and the adapter.
