Camera Bag
wyk_penguin
5:21 AM
I am looking for camera bags. Any suggestions?
I find the modern camera bages too suited for SLRs, being long and narrow, they aren't a good fit for RF gear. I have three lenses a 35mm, a 50mm and a 85mm together with one body (all FSU 😀 ). I carry 3 rolls of film (minimum), film picker, filters, sometimes I will also carry 1 flash (oh no, flash :bang: ). I don't want the bag to be too large and too obvious (i.e. camera bag like). What is your choice?
If you don't want the bag to look like a camera bag, then you've narrowed yourself down to the Domke F-802/803, J-802 line. There have been many threads discussing these bags in the past, best to do a search.
http://www.rangefinderforum.com/forums/showthread.php?t=6928
A previous thread, also hyperlinked at the bottom of this page, seems quite useful.
FWIW I use a black canvas Domke 803, with 2 additional pouches (slung on each end) & it comfortably holds 1 LTM & 1 M body with std/ medium- wide lenses attached, plus an additional 90mm, 6-8 rolls of film, a handheld meter, table tripod; odds & ends. Not enough room for a water bottle though. Doesn't scream out CAMERA BAG! (to my eyes at least)
David
Try going to a hiking supply store. Mountain Miser or Lowe have large Fanny packs that also have shoulder straps. You can add closed-cell foam for strategic padding.
Wear it in back when you are on the move. Rotate it to the front like a kangaroo pouch when you are shooting.
-Paul
Recommend the Domke F-802 (doesn't look like a camera bag and very practical) or the F6 (more traditional style bag but equally small, comfortable and discreet). Both hold a surprising amount of gear due to their minimal padding and scruff up beautifully after some use (think professional photojournalist) I like both of these bags so much I'm getting the bigger F-802 to carry my laptop to work - hope I can fit my Bessa R2a in it as well!
Billingham Hadley. Beautifully made, the padded insert provides excellent protection for the contents, and can be removed if you want to use the bag for other purposes.
Unfortunately, it's a little more expensive compared to either Domke or Crumpler bags.
