Hatchetman
Hello
I recently bought a Contax IIa from KEH. It seems to work OK, but I can't shoot an entire roll of 36. The shutter advance binds up like you've hit the end of the roll, but that is not the case. I am getting around 30 frames before this happens. It's like there is not enough room on the take up spool for any more film. The spool itself is a center feed one, meaning you have to trim the film leader equally on each side. The spool has a slot in the center rather than the bottom edge. The spool may have been married to a reloadable canister?
Any thoughts as to what is going on?
