Can you tell? Noctilux vs Noctilux vs Nokton
  • Noctilux f/0.95, Noctilux f/1, Nokton f/1.1
    Votes: 7 8.1%
  • Noctilux f/0.95, Nokton f/1.1, Noctilux f/1
    Votes: 4 4.7%
  • Noctilux f/1, Nokton f/1.1, Noctilux f/0.95,
    Votes: 3 3.5%
  • Noctilux f/1, Noctilux f/0.95, Nokton f/1.1
    Votes: 42 48.8%
  • Nokton f/1.1, Noctilux f/0.95, Noctilux f/1
    Votes: 26 30.2%
  • Nokton f/1.1, Noctilux f/1, Noctilux f/0.95
    Votes: 4 4.7%
  • Total voters
    86
redsky
8:36 AM
SLC, UT
Purely for fun. Noctilux f/0.95, Noctilux f/1, Nokton f/1.1
No editing other than cropping it to 5x7.
Same shutter speed, same white balance.
Click on the image to see full size. Answer on Post #25.
f1.1 ~ f0.95 ~ f1.0
If the shutter speed was constant it really can be no other way judging by the levels of exposure in the darker areas of the tree.
You can spot the 0.95 from a mile a way... worst bokeh I EVER seen on the edges (last 1/3) of any lens. I know this only because I owned one for five years. Do not miss that lens one bit. Junk.
Forgot to mention, but of course they are wide open and focused on the exact same point using LV with high magnification.
I found interesting how f/0.95 seems at first to produce a much shallower DoF than the other two, but I guess it's much more about the rendering of the out-of-focus areas than the size of the DoF itself.
This is interesting, I will give you guys the answer later on. For now a small clue: the solution is in the coma.
This is with the f/1.1 at full aperture. Maybe this helps.
Erik.
