newsgrunt
weather sealing on the Nikons is better than Canons. Also wait a bit since this year could offer up some new bodies if one follows the D3 upgrade timetable.
Actually I think with digital its quite possible to use a wide enough lens in portrait orientation to give the height you need whilst keeping the camera back vertical. Then with a decent tripod and camera set to rotate on nodal point, you can take multiple images and stitch them without needing a tilt shift lens. Maybe not all subjects but for a lot that will work unless you have non static subjects in or around the buildings.
Thanks all this has been very helpful. But now I have another question.
What is the distortion like on the Canon 24-105 F4.0L IS USM lens from 24 to 50. Do people towards the coners get bent? I assume the primes are better in this regard but maybe not as good as the zeiss lenses you can get for canon/nikon.
Or perhaps I should ask which of the zooms for canon or nikon that cover 24 thru 70 exhibits the least distortion at the wider end?
If you're using Adobe PS CS5 or LR3 distortion is not much of a problem with the 24-105 as there's a lens correction profile for it that gets rid of it. I have the 24-105 f4 L and it's the only Canon lens I currently own (I've rented others on occasion). I got this lens because I needed it mainly for studio work so the zoom reach was more important than speed. That being said, in daylight the large DoF at f4 up to 80mm is a bit annoying. If you like shallow(ish) Dof at shorter focal lengths go for the 24-70.
How soon do you need the camera? It seems like a lot is going to happen this year in Canon's camera and lens line-up so if you're not in a hurry it's probably a good idea to wait a bit.
I will buy two or three primes but a general purpose zoom would be useful if distortion is not a problem.
-Weatherproofing, durability - D700
Why do Canons DSLR's creak like an old sailing ship when you squeeze them ... I've always wondered about this?
An M9 won't give you clean low noise files at 6400 ... the D700 can do thiis all day! 😀
That said if you can stretch to an M9 do it ... I would! 😛
I already hate myself for considering a DSLR. It's like buying a PC. You research and research and research and then because there are simply so many variables you can't really decide which is the best way to go. Then you've spent so long researching that a new improved model is suddenly on the horizon and you have to start again. After becoming totally confused you end up buying what you had in mind in the first place without any research. At least an M9 wouldn't present these problems and nor would it require new lenses making the price competitive with a DSLR. Maybe not as versatile though.
