Sonnar Brian
Paul,
That is a good system. I can account for all 35 years of my Minolta Hi-Matic 9 camera, kept in a case and repaired twice in its life. The Hi-Matic E I got lucky on.
I had an Nikon S2 that had a similar problem to what you describe: It turns out that the last person to take the lens mount off did not replace all of the Shims that set the flange-to-film distance. I used the opportunity to re-shim it for the Zeiss Sonnar. I discovered the Canon 7 uses a shim under the mount. It is a ring of thin brass.
I have a "parts" Canonet 28; I am going to play with it in a similar fashion; see how hard the lens barrel is to go back on.
