goamules
On expired Tri-X 400:
Usually when people talk about optimizing a lens now, they mean making the focus accurate at one fstop and less accurate at others by moving either changing the shims (moving the full optics module closer or further from the plane) or by changing the distance between the optics (inserting a shim).
Usually that comes up with sonnars as the design has focus shift. Some people prefer the rangefinder to be correct at 1.5 at the cost of it being less accurate stopped down (often compromising around f2.8-4 as beyond that the depth of field makes up for the different).
At f/1.4, the Nikkor 50mm ltm lens is sharp and contrasty up close but flares significantly at distance. Stopped down slightly, its great across the range. Given the 1.4 performance, I think its fair to say that they prioritized near focus image quality over far focus.
Reading this thread has made me think that I should get one of my two Canon 50mm f1.5's optimized for wide open - close up
and leave the other as it left the factory (optimized at f4).
Or should I leave both Canon f1.5's as they are and get a Nikkor 50mm f1.4 to use open wide and close up.
If I did optimize one of the Canon f1.5's for f1.5 would it produce results similar to the Nikkor 50mm f1.4 or would the Nikkor still
have the edge wide open?.
Your thoughts on this matter would be of interest.
Many thanks.
...The faster you try to design a lens, like a sonnar, the harder it is to have good resolution with few aberrations...almost all designs are better stopped down.
Canon made their 50/1.5 based on their determinations for the above, and manufactured all lenses, with tight quality control and checking to that design. How would someone now, 50 years later, change that and "optimize a Canon sonnar for F1.5?" It's a set lens design, it was optimized in 1952.
...My repairer Malcolm Taylor in the U.K.is fully equipped to do all lens work and he can perform his "magic" with most optics and does superb work on Leica,Canon and Nikon cameras and optics for worldwide clients.
I will then have a Canon f1.5 factory optimized for f4 for general photography and the second Canon f1.5 optimized for f1.5 when I require to use it close up and at full aperture (eg. portraiture)
