Canon ltm 50mm f1.8
The later, black ones tend to develop a haze type of fungus which can't be cleaned.
The same appears to the 50/1.2, released in 1956 as well.
With later lenses, i.e. the 50/1.4, this was resolved.
I never heard of a *chrome* 50/1.8 with fungus, but the black version was said to be optimized in design with newer glass types.
My 50/1.8 has a hard stand against the (classic looking) 50/1.5 and the newer, dead-sharp 50/1.4. The outcome of the 50/1.8 is just in between, so it's hard to decide when to use it. But if you want just *one* Canon 50mm, or have a low budget, then the 50/1.8 is the one you need!
My tribute to C. 50/1.8:
The Canon f/1.8 isn't a 'low budget' lens, its just a great lens for less money than alternative over-hyped lenses. It is a perfect fit on an LTM Leica for size and style, and at half the price of a Summicron. The prices are going up for good examples though, and like any sleeper it will have its day.
Steve
Raid,
I'm with Steve on this one. I have two copies of the 50/1.8 and one copy is very prone to haze, the other not. The one that is not does not seem to render as your example one.
I am struck in your tests by the (apparently) huge difference in contrast, not to say detail, between the 50/1.4 and the 50/1.8. I also have th e1.4, and I do not witness that difference w my 1.8.
Apologies for not posting photos; I'll catch up with digitizing and uploading one day -- hopefully this year.
Giorgio
It's a 40mm, I believe. This size is a bit thin on the ground, but can be found used without too much effort. Third-party versions, such as made by Kalt, are not uncommon.
P.
Mine came with an Ednalite 617 Series VI holder. So I'll save on 1: Filters (of which I already have a set or two), and 2: a hood (just found an Ednalite Series VI hood, too). The original is too rare and expensive for me right now.
PF
Raid,
Giorgio
Hi Georgio,
Tests are not free of flaws; I checked carefully for lenses with haze or similar problems, and then I removed the images that were taken with such lenses. Still, I am not perfect. 😀
Hi Georgio,
Hi Raid,
No criticism, nor a request for perfection; just adding my experience.
Giorgio
One good thing about the Canon 50mm 1.8 is that cleaning the surfaces of the lens groups is relatively easy - the lens disassembly is relatively straight forward.
My had some has on the back of the rear element in the front group. It looks like the lens itself had a lot of oil migration in general as almost every surface inside was a bit oily. Only took about half an hour to tear down and clean (though I'd done a partial disassembly before and was familiar with at least getting the first group out).
I just looked at my two 50/1.8 lenses.
I removed front and back covers,and then I pointed a strong light at the front of the lens and then I looked from the back. Is there a "best" way to check for haze? Should I go to a dark room? I cannot see haze as clearly as someone here has shown his lens with haze.
