Carl Zeiss 16mm 2.8 on Olympus E-PL1
raid
Dad Photographer
1:43 AM
Florida
I just had to try out this combo. Recently, I bought at RFF a Zeiss 16/2.8 fisheye lens (for the Rollei QBM system). I do not like fisheye lenses. With a M 4/3 camera, I get a 32mm view that is not distorted too much (so to speak). Here is my first set of images with this lens.I used LR5to transform DNG to JPG files, but I did not add contrast or do anything else.
Link: https://raid.smugmug.com/Zeiss1628E-PL12019/i-Sc9vGQB
It was as easy to use it as with a small snapshot camera. Everything is in focus, and I hold the camera-lens by the lens. It was a $200 purchase for a high quality Zeiss lens. I compose through the view at the back of the camera. The lens feels solid like a rock, with easy changes in the aperture and hardly and focus change.
Taken outside Joe Patti's Seafood Store, Pensacola, Florida.
When I see dense fog in the morning, I may stop here for 30 minutes or less before I drive to work. It is not far off my daily drive.
I often stop at this coffee shop for some coffee in the morning.
Yes, Doug, this is the 16mm fisheye lens with m 4/3. The AE is most likely affected greatly by white sand and strong sunlight and clear sky. If I slightly tilt the camera/lens, the fisheye effect shows clearly.
