Sonnar Brian
I remember that! Looked it up in Thiele. Figured since there were TWO made, I was not going to fall into one- so I converted a Contax mount lens to LTM using a J-11 mount. It is a remarkable lens.
Thank you so much dexdog. That's super interesting. And it basically confirms the hunch that this is a prototype of some sorts.I just unscrewed the optical block out of the focus mount/lens mount. There was a bit of a hang-up when the optical block unthreaded, which kinda scared me given that this was the first time I had ever tried to take it apart! Anyway, I took pics of the lens mount at close-focus and infinity...not the best pics, but you get the idea. There is no delimiting screw, and it appears that the helical in the lens mount bottoms out on the lens mount at infinity
Close focus at 0.9 meters
Infinity focus
Sonnar B, feel free to split the discussion of the 1933 LTM Sonnar into a separate thread to avoid bogarting the 5.8cm Sonnar thread.
The thing is though that they are Carl Zeiss Jena lenses.I thought that it is widely known that the CZJ Sonnar 5,8cm F/1.5 is a ... not original Carl Zeiss Jena lens.
Hartmut Thiele mentions this lens in his "Fälschungen - Kameras und Objektive" ( there is even an image of the Leica-Sonnar 5,8cm on the books cover) and in "Legenden und Geschichten zur Leica". His books are in German but he provides a list of known Zeiss serials of frauds in there too. He is even mentioning that the CZJ Sonnar 5,5cm and 6cm are frauds too.
There are unrecorded details that are just not in the book. In Thiele there are some serial numbers listed with "receipt missing", but are regular production lenses. I've taken apart Wartime lenses, irregular production lenses, ZK Sonnars, and early J-3's. Once they are disassembled, is not too difficult to tell one from another. The serial numbers stamped into the inner parts of the LTM Zeiss lenses is also a good indicator.It is the same issue with the first batches of Jupiter Sonnars. The soviets took almost everything from the Jena factories including parts, lens bodies and glass. They even took engineers and brought them to Kiev. Then they started the Jupiter production. In the beginning they assembled the incomplete lenses and used up all spare parts. Since they started the Jupiter production with the original production machines, with the original engineers and with the original glass one could argue they produced Jena Sonnar lenses. Today it is very difficult to tell an original CZJ Sonnar lens apart from a Kiev-assembled or from an stolen-parts-assembled one. Your best shot is the Thiele Nummernbuch since Mr. Thiele got the production cards from CZJ Saalfeld factory. If there is no production card than chances are high it is an irregular lens.
After the Jupiter production used up all the Schott glass they had to use other glass available in the CCCP. So they did a recalculation of the Sonnar 50mm F1.5 design in 1954. After this they used the new calculated Sonnar design. I would say it was a successful recalculation since it is as good or a little better than the previous wartime design from Bertele. Maybe the used coating improved it over the previous design.
