Change settings after winding?
asfarley
12:07 AM
Hi, I've seen various advice related to changing aperture/shutter speed after winding the shutter.
Specifically I'm wondering about a Minolta Hi-Matic 7S; I've accidentally done this a couple of times. Is the damage cumulative, or can it potentially cause something to actually break? Is there some tolerance built in that allows this to happen a few times without major effects?
Correct me if I'm wrong, but I think this applies only to Leica screwmount cameras and their copies. Contax might also be subject to this rule, but I heard otherwise. It has to do with slow speed mechanism being damaged. Minolta 7S uses electronic leaf shutter,and you can change its speed whenever you want.
I think it's advised for those, to change the shutter speed ONLY after winding. However, I'm wondering if it's OK on the 7S to change aperture or shutter
speed after winding. I don't think it's recommended, at the very least.
*Edit I didn't actually see your statement about the electronic shutter, that's good to know.
I've used a Minolta 7s for years and never read or heard about changing speeds only after winding. 😕 I've done it both ways and it's still taking pictures to this day. I've never used it on auto as my meter seems off. 🙁
With a leaf shutter you can change the shutter speed at any time. A few leaf shutters require you to set the speed before cocking - but this is relatively rare.
The advice about setting shutter speeds after winding pretty much only applies to older designs of focal plane shutters which utilize a lift and set, rotating knob. Such as screw mount Leicas, Kiev MF SLRs, and a few other oldies.
On the other hand there are some such shutters that can be set before or after winding, such as on the Prakticas and early Mirandas.
