Dante_Stella
Rex canum cattorumque
Totally correct. And, the UC is a 43mm filter, while the chrome lens is a 46mm filter.
The UC is sharper. The chrome lens is less coated and identical to the Hexar lens. The Hexar corrects the slight focus drift in its AF, but the chrome lens 'suffered' from it, it's really not all that extensive. The UC coating corrected that.
If the UC is "better" with focus shift (as opposed to just shifting the focus to mask the problem as is done on ZM Sonnars), that necessarily means it has less SA (and probably worse bokeh). I haven't seen anyone make the claim that one is sharper than the other. The reality is that a lot of lenses will max out a 24mp sensor, so it may be hard to observe.
If the chrome is 46mm, that would be awesome, since I have pretty much every type of 46mm filter ever made, including redhancers, prisms and nebulas. But I guess I need to send that chrome 43mm B+W filter back to Adorama. 🙂
You can actually manipulate the focus on wideangle screwmount lenses by using different M adapters. I measured 30 of them from many sources, and there is a pretty big spread (0.94-1.02). When the silver one gets here (and assuming it arrives safely), I'll shoot them both against my LensAlign on a 240 and 246, and we can see if there is a focus shift difference.
Dante
